  3. Disable GUI until runs complete
  • Views 14890
saurabh96
saurabh96 over 5 years ago
Hey Andrew,
Is there any method through which we can disable GUI until it runs complete...
Let me brief more...Suppose when I press the run button in GUI, the process starts running, and it will search for xyz.il file in pwd in the loop as soon it finds it will stop and run completes...Now I want that upto till the run is completed; I cannot enter any new data in GUI as it is in disabled form..?
I have gone through this form-- community.cadence.com/.../skill-code-to-disable-all-callbacks ...but I think this is for CDF?
Any help would be highly appreciated!
    You could use hiSetFieldEnabled for each of the fields on your form when the process starts, and then call it again to re-enable the fields when the process finishes (my assumption would be that you use ipcBeginProcess to launch the job and use the exit handler argument for that function to be triggered when it completes).
  • saurabh96
    saurabh96 over 5 years ago in reply to Andrew Beckett
    Greetings Andrew,
    For the test cases, I am trying, it contains more than 50 different fields...using hiSetFieldEnabled for each field and then again calling will be a huge time -taking..isn't there another way ..through which we can achieve this?
    Yes... I am using ipcBeginProcess to launch the job below the code I am using.
    procedure(Runform(form)
    let((cmdPid abcStdout)
    cmdPid = ipcBeginProcess("./abc.sh")
    ipcWait(cmdPid)
    while(abcStdout=ipcReadProcess(cmdPid)
    printf("%s" abcStdout ) ;
    if(!ipcGetExitStatus(cmdPid) == 0 then
    error("abc: couldnot run\n")
    Andrew can you elaborate more how to do this using any example?
    Thanks in advance,
    Andrew Beckett over 5 years ago in reply to saurabh96
    This is nonsense. I just used some code I had lying around which creates a big form and had it create 400 fields on the form. I then ran the function to enable or disable them all through the SKILL profiler and it was actually below what could be measured (so definitely less than 0.01s). Even the top-level and parser took less than 0.1 and that was with me calling the function to disable the fields and hitting the start/stop buttons for the profiler.
    If there had been another simpler way to achieve this, I'd have suggested it.
    In addition, if you're invoking the command using ipcBeginProcess() followed by ipcWait, then Virtuoso will block until it completes - so you won't be able to interact with the form anyway. You could (as I suggested in a previous post) use the exit handler (i.e. the asynchronous way of using ipcBeginProcess) which would mean that the UI wouldn't block. This can be seen in this code below (extending my sample code to create a big form). Call abDisplayBigLayoutForm(30) and then hit the Apply button - all the fields will be disabled, and then 15 seconds later (the ipcBeginProcess is just launching "sleep 15" to illustrate the principle) all the fields will be re-enabled again.
    procedure(abDisplayBigLayoutForm(numFields)
        abCreateBigLayoutForm(numFields)
        hiDisplayForm(abBigLayoutForm)
    procedure(abCreateBigLayoutForm(numFields)
        let((fields field label gridLay)
            for(i 0 numFields
                field=hiCreateStringField(?name concat('myfield i))
                label=hiCreateLabel(?name concat('label i) ?labelText
                    sprintf(nil "Field %d" i)
                fields=tconc(fields list(label 'row i 'col 0))
                fields=tconc(fields list(field 'row i 'col 1))
            fields=tconc(fields list('col_stretch 0 0))
            fields=tconc(fields list('col_stretch 1 1))
            fields=car(fields)
            gridLay=hiCreateGridLayout(
                'gridLay
                ?items fields
            hiCreateLayoutForm(
                'abBigLayoutForm
                "Big layout form"
                ; Add a stretchable region below the grid so that
                ; the fields don't spread out vertically
                hiCreateVerticalBoxLayout(
                    'vbox
                    ?items list(
                        gridLay
                        list('stretch_item 1)
                ?minSize 600:200
                ?callback 'abBigLayoutFormCB
    procedure(abBigLayoutEnableFields(form enable)
        foreach(field form->fieldList
            hiSetFieldEnabled(get(form field) enable)
    procedure(abBigLayoutFinished(ipcId status)
        printf("FINISHED\n")
        abBigLayoutEnableFields(abBigLayoutForm t)
    procedure(abBigLayoutOutput(ipcId data)
        printf("OUTPUT: %L\n" data)
    procedure(abBigLayoutFormCB(form)
        let((ipcId)
            abBigLayoutEnableFields(form nil)
            ipcId=ipcBeginProcess("sleep 15" "" 'abBigLayoutOutput
                'abBigLayoutOutput 'abBigLayoutFinished
