  3. Scope of effect of the syntax desVar("")
  • Views 2341
ExcaIibur
ExcaIibur over 5 years ago
I have a function that is partitioned as following and during debugging of the pre-run script, I noticed that the scope of effect of the syntax desVar("") is not what I expected and remains unclear to me.
;main()
code=1;
while (target not met)
     procedure_measure_analog_metric("A")
     printf("current code is %L\n" evalstring(desVar("code")))
     code_next = 2*code;
     desVar("code" code_next)
     code= code_next
      printf("next code is %L\n" evalstring(desVar("code")))
;procedure_measure_analog_metric(net_name)
ocnxlLoadCurrentEnvironment( ?noAnalysis t)
ocnxlSetCalibration()
analysis('ac ?start "10k"  ?stop "1G"  ?dec "5"  )
printf("code inside sub-proc is: L\n" evalstring(desVar("code_rf1")))
ocnxlRunCalibration()
if(net_name=="A")
then
    SimResult = ymax(vfreq('ac "A"))
else if(net_name=="B")
then
    SimResult = ymax(vfreq('ac "B"))
The outputs I get are:
current code is: 1
next code is: 2
code inside sub-proc is: 1
What I expected are:
current code is: 1
next code is: 2
code inside sub-proc is: 2
It looks like desVar("var_name" var_value) is only effective until another ocnxlLoadCurrentEnvironment() and/or ocnxlSetCalibration() is declared.
My question is:
1. If so, what is the correct syntax to extend the value of code_next into the sub proc?
2. When my scenario is I need to calibrate analog performance a,b,c,d,.etc, but all the analysis are the same (i.e. analysis type, nr. of points. .etc). Then, can I just use one set of ocnxlLoadCurrentEnvironment() and ocnxlSetCalibration() at the top of my main script, followed by multiple ocnxlRunCalibration() that are splitted inside loops, and eventually ended by ocnCloseSession() at the end of my main script?
    The simplest approach would be to make your function do something like this: procedure(procedure_measure_analog_metric(net_name @optional code) let((SimResult) ocnxlLoadCurrentEnvironment( ?noAnalysis…
    let((SimResult)
      when(code
        desVar("code_rf1" code)
      if(net_name=="A")
      then
      then
      ; return the result
      SimResult
    Then in the main code:
    code=1;
         result=procedure_measure_analog_metric("A" code)
         printf("current code is %L\n" code)
         code_next = 2*code;
         code= code_next
          printf("next code is %L\n" code)
  • ExcaIibur
    ExcaIibur over 5 years ago in reply to Andrew Beckett
    Thanks Andrew for the idea. That can work.
