  3. How to check the 90 degree angle on the route
  • Subscribers 150
  • Views 13806
yankunRen
yankunRen over 5 years ago
Hi all
      I have a problem at work. I use virtuoso 6.1.6-64b.
      As shown below. How can I use skill to check the 90 degree angle on the path (or pathSeg、polygon、rect).
      Hope you can give me some ideas, or some skill functions.
      Or use other methods or tools to check.
Thank All.
    You can use this code below (I just quickly wrote this, so hopefully you can see the approach to use).
    Given a set of selected objects, using abCheckObjectsOrthogonal(geGetSelSet()) will return t if all objects only have 90 degree angles, or nil if any do not.
    /* abCheckObjectsOrthogonal.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jul 09, 2021
    Modified
    By
    Function to determine whether an object or list of objects
    are all orthogonal (i.e. have 90 degree angles only)
    SCCS Info: @(#) abCheckObjectsOrthogonal.il 07/09/21.11:03:43 1.1
    *               abCheckObjectsOrthogonal(objects)                *
    *      Given an object (or list of objects) return whether       *
    *  all objects are orthogonal (if any object is not orthogonal   *
    * then return nil). Only checks rect (which must be orthogonal), *
    *      polygon, path, line and pathSeg - everything else is      *
    *  orthgonal (perhaps ellipses, donuts and arcs should not be,   *
    *         but these don't appear in layout that often!)          *
    procedure(abCheckObjectsOrthogonal(objects)
        let((points closed orthogonal lastPt)
            unless(listp(objects)
                objects=list(objects)
            forall(object objects
                    orthogonal=nil
                    ; Determine the point list and whether the point list
                    ; is for a closed shape
                    case(object~>objType
                        ("rect"
                            orthogonal=t
                        ("polygon"
                            points=object~>points
                            closed=t
                        (("path" "line")
                            closed=nil
                        ("pathSeg"
                            points=list(object~>beginPt object~>endPt)
                            closed=nil
                        (t
                            points=nil
                            closed=nil
    		; Successive points either have the same x or same y
    		; to be orthogonal
                    unless(orthogonal
                        lastPt=car(points)
                        orthogonal=forall(point cdr(points)
                            prog1(
                                xCoord(point)==xCoord(lastPt) ||
                                    yCoord(point)==yCoord(lastPt)
                                lastPt=point
                        when(closed && orthogonal
                            orthogonal=
                                xCoord(car(points))==xCoord(lastPt) ||
                                    yCoord(car(points))==yCoord(lastPt)
                    orthogonal
  • yankunRen
    yankunRen over 5 years ago in reply to Andrew Beckett
    Thank you for your help, I have made progress.
    Regards
    yankun
