  3. Variable inside rexCompile function
  • Views 12138
Kd339
Kd339 over 5 years ago
I have a list of patterns that should be matched or compared with target string( inside for loop). So is it possible to define a variable that holds the matching pattern.
If not possible any alternative solutions?
    Use pcreCompile and the other pcre functions instead; these return and use a pattern object which can be used to store the compiled pattern in a variable:
    var1=pcreCompile("somePattern")
    The "rex" functions are very old and only support very basic regular expressions, where pcre (Perl Compatible Regular Expressions) is much more powerful.
