  3. ADE setting run options using SKILL
  • Views 11862
Weijie JIang
Weijie JIang over 5 years ago
I have a problem setting the DUT lists for Monte-Carlo run option in SKILL. For example, when I execute the following codes
axlNewSetupDBLCV(LIBNAME CELLNAME "adexl")
x_mainSDB = axlSetMainSetupDBLCV(SESSNAME LIBNAME CELLNAME "adexl")
devHandle = axlGetRunOption(x_mainSDB "Monte Carlo Sampling" "dutsummary")
I am informed that devHandle is nil because it does not exist. I know that if I open it in GUI and set it manually it will be created. But how can I initialize it using SKILL?
Best regards,
Weijie
    If devHandle is 0, then you need to do: devHandle=axlPutRunOption(sdb "Monte Carlo Sampling" "dutsummary") Which will create a new run option with that name, and you can use axlSetRunOptionValue to…
    Which will create a new run option with that name, and you can use axlSetRunOptionValue to change the value.
