  3. Creating instances and naming them in a definite manner...
  • Views 15395
Creating instances and naming them in a definite manner using a loop
Sattiwk
Sattiwk over 5 years ago
I am trying to create N instances and name them as xI1, xI2......,xIN using a loop and add them in a list. I have a written code that does the same for 4 instances as shown below (code snippet).
; Create library and cell for the scaled copy
dbCreateLib("__distCalcLib")
x1cp=dbCopyCellView(x1m "__distCalcLib" "__distCalcCell" "symbol")
dbSave(x1cp)
x1cpsch=dbOpenCellViewByType("__distCalcLib" "__distCalcCell" "schematic" "schematic" "w")
dbSave(x1cpsch)
; Have 4 instances(one for OP, three for scaled signals)
; add code-Currently, y spacing is hard coded-modify to determine size and spacing from the size
xI1=schCreateInst(x1cpsch x1m "I1" '(0 0) "R0")
dbCopyProp(x1 xI1)
xI2=schCreateInst(x1cpsch x1m "I2" '(0 5) "R0")
dbCopyProp(x1 xI2)
xI3=schCreateInst(x1cpsch x1m "I3" '(0 10) "R0")
dbCopyProp(x1 xI3)
xI4=schCreateInst(x1cpsch x1m "I4" '(0 15) "R0")
dbCopyProp(x1 xI4)
; One list for the operating point and three for scaled signals
opInstList = cons( xI4 nil )
sigInstList = list( xI1 xI2 xI3 )
I tried to write a code to achieve my goal.This is my effort.
; Have N instances
numCopies=4
counter=1
instanceIndex='()
opInstList='()
sigInstList='()
while(counter <= numCopies
ySpace=5*counter-5
instanceIndex =append(instanceIndex schCreateInst(x1cpsch x1m sprintf(nil, "xI%d" counter) '(0 ySpace) "R0"))
dbCopyProp(x1 instanceIndex[counter-1])
if(counter==numCopies then
opInstList =cons(nth(counter-1 instanceIndex) opInstList)
else
sigInstList =append(sigInstList nth(counter-1 instanceIndex))
counter=counter+1
I am not getting the desired output. The lists are empty and no instances are getting created.But the length of the lists are correct but the 'sigInstList' shows (nil,nil,nil) for N=4.
I am new to skill programming, so I couldn't figure out how to fix this and am seeking for help. Also, before creating the library, I want to add a code to check whether the library of same name exists or not and if it exists, it must be deleted.
I just want to automate the first code for N instances. Please help me out.
I am using cadence version IC6.1.7-64b.500.3.
  • mbracht
    mbracht over 5 years ago +1
    Hi, Your function schCreateInst(...) goes wrong - reason is that you pass the instance's origin (the 4th argument of schCreateInst() as a quoted list: '(0 ySpace) That way ypSpace is not turned into…
  • ebecheto
    ebecheto over 5 years ago +1
    Hi, You should learn how to use foreach(mapcar ...) functionality. See example : ; Create library and cell for the scaled copy dbCreateLib( "__distCalcLib" ) x1cp=dbCopyCellView(x1m "__distCalcLib…
  • mbracht
    mbracht over 5 years ago in reply to ebecheto +1
    good point! I think it'd be even more important to check the return value of schCreateInst() in the first place and indicate at least a warning in CIW or maybe even throw an exception. Just seeing a…
  • mbracht
    That way ypSpace is not turned into a value but remains a symbol. As a result schCreateInst() fails..silently unfortunately... and returns nil.
    Use (list 0 ySpace) instead and you should be ok.
    Max
  • Sattiwk
    Sattiwk over 5 years ago in reply to mbracht
    Thanks mbracht, it worked fine. Can you explain when to use quoted list and when not to? What is the difference between the two? I just want to know so that I don't make similar mistakes in the future. Thank you for your time.
  • ebecheto
    x1cp=dbCopyCellView(x1m "__distCalcLib" "__distCalcCell" "symbol") dbSave(x1cp)
    cv=dbOpenCellViewByType("__distCalcLib" "__distCalcCell" "schematic" "schematic" "w") dbSave(cv)
    ns=linRg(0 3 1);=> (0 1 2 3)
    xys  =foreach(mapcar n ns list(0 n*5));=> ((0 0) (0 5) (0 10) (0 15))
    insts=foreach(mapcar xy xys schCreateInst(cv x1m "I4" xy "R0"));=> (db:... db:... db:... db:...)
    returned=foreach(mapcar inst insts dbCopyProp(x1 inst))
    Considering the declaration of a list. When you manually declare a list, you can use quote.
    Myvar='(1 "a" 3) ;=> element in the list are not evaluated
    when you compute a list, you should use list(1 "a" 3)
    Hope it helps
  • mbracht
    good point!
    I think it'd be even more important to check the return value of schCreateInst() in the first place and indicate at least a warning in CIW or maybe even throw an exception. Just seeing a nil as an element in the list returned by (foreach mapcar...) makes it difficult to relate that to the instance that failed to be placed.
  • mbracht
    mbracht over 5 years ago in reply to Sattiwk
    A qoted list silently applies the quote to each and every element in the list. And applying a quote to a symbol prevents it from being evaluated as a SKILL expression,- in your specific example ySpace.
    ySpace = 5.0
    (list 0 ySpace) ---> (0  5.0)
    '(0 ySpace)     ---> (0 ySpace)
    So in case of the quoted list you get back the SKILL symbol.
    You should make yourself familiar with the concept of symbols - they are really crucial in SKILL. A symbol in SKILL is essentially just a name that can be used (potentially simultanously) for a variable, a function or a property list.
    regards
    Max
  • Sattiwk
    Thank you mbracht and ebecheto BlushBlush
