  3. Stop Pegasus RV from CIW(using skill commands)
  • Views 1714
AmarDas
AmarDas over 5 years ago
I could able to invoke the Pegasus RV using "pegasusStartRV" command. However I couldn't find a way to close the opened RV window with skill commands.
I know user can close it manually. Is there any "automated way/skill commands" also to close the RV window ?
Thanks & Regards,
Amar
    Amar,
    I don't think this is possible currently. As far as I can see there's no public function to do it either (nor private). So you will need to request this to customer support.
  • AmarDas
    AmarDas over 5 years ago in reply to Andrew Beckett
    Thank you for clarifying. I will contact customer support if needed.
    Amar
