  3. Print combobox option in ciw window
  • Views 13105
saurabh96
saurabh96 over 5 years ago
Hey there,
How can i print combo box option (selected by user) in ciw window...Let me elaborate more...suppose..i have below combo box:-
rule1
rule2
rule3
rule10
now if user select rule2 and if i run the process..if process run successfully ..print rule2 completed in CIW.....same as if  user select rule 10  and  if process run fails.. print rule10 failed in CIW.
Thanks in advance.
srv
    Seriously?
    You write some code to do that. It's not hard.
  • saurabh96
    saurabh96 over 5 years ago in reply to Andrew Beckett
    thanks fr reply,
    am getting an error while trying it as
    *Error* fprintf/sprintf: format spec. incompatible with data - "Format is '%s Completed ..please check log files\n', argument #1 is (\"2\")"
    below code i have tried
    rules_Entry=hiCreateListBoxField(
    ?name 'rules_Entry
    ?multipleSelect t
    ?choices (list "1" "2" "3" "4" "5" "6" "7" "8" "9"  ))
    rules_check = form->rules_Entry->value
    sumfile=simplifyFilename("./sum")
    if(system(strcat("grep -q '" "RUN COMPLETED" "' " sumfile))==0 then
    printf("%s Completed ..please check log files\n" rules_check)
    else
    warn("Rules Failed...please check log files\n")
    Andrew Beckett over 5 years ago in reply to saurabh96
    Isn't that obvious, and something you could figure out with a little testing? For list boxes (so it's not even a combobox as you described in your original post), multiple selection is possible (you've even enabled it in your code snippet), so form->rules_Entry->value is a list of strings, not a single string.
    rules_check = buildString(form->rules_Entry->value ",")
    would fix your code above, because it takes the list of selected values and converts it into a single, comma-separated, string.
    Clearly you can see that providing a code example and the actual error makes it far easier to give you an answer (rather than requiring us to read your mind), but even so, your description didn't actually match what the code was doing!
  • saurabh96
    Thanks Andrew for explanation.
    i have one more question in above..i have made another test-case in which...
    ?name 'rules_Entry
    ?multipleSelect t
    ?choices (list "1 (a)" "2 (b)" "3 (c) " "4 (d)" "5 (e)" "6 (f)" "7 (x)" "8 (y)" "9 (z)"  ))  ;;;;where a,b,c defines the rules for particular no.
    in above case if i  select rule 1 and 2 , it print it will print like ( 1 (a) ,2 (b) ) completed...
    but i want that it will print only number come not alphabets as (1,2 completed).
    i have tried with grep and awk but it didnt work
    leadingNum=pcreCompile("^\\d+")
    filtered=foreach(mapcar entry form->rules_Entry->value
      pcreExecute(leadingNum entry)
      pcreSubstitute(leadingNum "\\0")
    rules_check = buildString(filtered ",")
    or simpler still without needing patterns (if you just want to take the first word in your choices, i.e. using parseString to pull part the choice):
        car(parseString(entry))
