  3. how to set tcl version in skill file
  • Views 12921
saurabh96
saurabh96 over 5 years ago
Hey there,
How can we set the TCL version in the skill file to override the virtuoso Tcl version?
For example, I tried the below steps but its not working..pls guide me to what's the mistake?
abc.sh is my run file.....inspite defining the tclsh version, still its taking the virtuoso TCL version
command=strcat("export FILE_tclsh=OSS-tcltk-/8.6.9")
command=strcat("xterm -ls -hold -e \"./abc.sh -version\"")
command = strcat(command " -parentTool virtuoso")
cmdPid = ipcSkillProcess(command)
ipcWait(cmdPid)
printf("Finished\n")
  • mbracht
    mbracht over 5 years ago
    I don't know whether that will eventually solve your problem but the above code can never work. The "export FILE_tclsh...." part will never get executed because you overwrite it with the second strcat command. I guess what you really wanted to do is this:
    command=strcat("export FILE_tclsh=OSS-tcltk-/8.6.9 ; ")
    command=strcat(command "xterm -ls -hold -e \"./abc.sh -version\"")
    Note the trailing semicolon of the export command - it is required to separate it from the "xterm" command.
    Max
  • saurabh96
    saurabh96 over 5 years ago in reply to mbracht
    Thanks Max
    issue gets resolved!
