  3. Load a SKILL function using an ENV variable
  • Views 16205
Michael Kolesnik
Michael Kolesnik over 5 years ago
I would like to load SKILL functions by using a shell ENV variable instead of a hard path.
Setting the skill path is not a solution.
In the shell I set the ENV:
setenv MDTOOLS "/home/MDTools"
trying to load this fails in the CIW:
load("$MDTOOLS/MDT_MarkCoordinate.il")
*Error* load: can't access file - "$MDTOOLS/MDT_MarkCoordinate.il"
checking I can see the path is correct:
getShellEnvVar("MDTOOLS")
"/home/MDTools"
What am I missing?
  • skillUser
    skillUser over 5 years ago
    Hi Michael,
    Depending on the version of Virtuoso it may not expand Unix env vars for you (only the most recent versions do this I believe, IC6.1.8 and ICADVM20.1), so it is best to do that yourself, in other words:
    loadi(strcat(getShellEnvVar("MDTOOLS") "/MDT_MarkCoordinate.il"))
    Best regards,
    Lawrence.
    Andrew Beckett over 5 years ago in reply to skillUser
    Laurence,
    As far as I know (and from experimenting too), environment variables are not expanded in IC6.1.8/ICADVM20.1 either (by load/loadi).
    There is my article: SKILL: How can I expand environment variable references in a string?
    load(CCSexpandEnvVars("$MDTOOLS/MDT_MarkCoordinate.il"))
    but you can also use the built-in simplifyFilename:
    load(simplifyFilename("$MDTOOLS/MDT_MarkCoordinate.il"))
    That works from IC6.1.7 onwards (I tried some earlier versions, and it changed during an IC616 hotfix but I didn't bother trying to track down which ISR it changed in).
  • skillUser
    skillUser over 5 years ago in reply to Andrew Beckett
    Yes, I must have been thinking of the simplifyFilename() function - older versions wouldn't expand Unix Env Vars, but the more recent versions of Virtuoso do now, thank you :-)
    Lawrence - I was thinking "Cool, we've implemented that, maybe I just missed it" - so was slightly disappointed to find that we hadn't after all ;-)
  • Michael Kolesnik
    Michael Kolesnik over 5 years ago in reply to Andrew Beckett
    They both work perfectly.
    Thanks, both of you for the very quick response!
    I have another question on Fill pattern implementation but I will start a new request on that...
