  3. How to set default values in radio field
  • Views 13113
saurabh96
saurabh96 over 5 years ago
Hello Guys,
i have created radio field below and call their default value(i.e "",-excute1 and -excute 2) from radio field ..am facing an issue when am selecting any radio button its value is coming "nil"  ...as (form->radio_entry->value) is coming nil..how to correct it-
below code -
radio_Entry=hiCreateRadioField(
?name 'radio_Entry
?choices list("None" "Check1" "Check 2")
?value "None"
?enabled t
?callback list("MyFields(hiGetCurrentForm())")
procedure(MyFields(form)
case(form->radio_Entry->value
("None"
form->->value=""
("Check1"
form->->value="-excute h1"
("Check 2"
form->->value="-excute h2"
  • mbracht
    mbracht over 5 years ago
    Hi
    The value slot of the radio field data structure must be one of the strings defined in the ?choices list - watch your CIW output and you will see a warning about this:
    WARNING* Form 'MyForm', field 'radio_Entry': Bad value "Ceck1".
        Radio value must be one in the list of choices.
    Other than that this callback is totally useless - the assignment to the value slot happens automatically when you click one of the radio buttons, why would you want to overwrite it???
    Max
  • saurabh96
    saurabh96 over 5 years ago in reply to mbracht
    Hey max,
    thank you for quick response.few questions
    1) If i defined "None" in radio value, as it is defined in  radio choices also..shouldn't is right??
    2) if we don't use callback, how i can append values as radio choices and their respective values are different.
    let me brief more
    Actually i have scenario in which i have to write the input given from radio field into file.   fprintf(cell "-chk %L " form->chk_path_enter->value );cell is file name
    so if user selects none then value should be  = blank("")
    same if check1 then value should be=  -excute1
    check2 then value should be =  -excute2.
    regards,
    srv
    Andrew Beckett over 5 years ago in reply to saurabh96
    So your code doesn't match the picture, and I've no idea what the ->-> bits were for. Anyway, I made some small modifications to the code and now you have a ->chk_path_enter->value you can retrieve:
    It would be far better if you provided a complete example, and I'm rather surprised after the help on the previous topics that you're unable to get this kind of thing working. None of this is that complicated!
      ?name 'radio_Entry
      ?value "None"
      ?enabled t
    hiCreateLayoutForm(
      'MyForm
      "SRV form"
      hiCreateFormLayout(
        'lay
        ?items list(
          radio_Entry
          hiCreateStringField(
            ?name 'chk_path_enter
            ?editable nil
        ("None"
          form->chk_path_enter->value=""
        ("Check1"
          form->chk_path_enter->value="-excute h1"
        ("Check 2"
          form->chk_path_enter->value="-excute h2"
    hiDisplayForm(MyForm)
