  3. Selection of visible objects in layout
  • Views 14141
Annaliza
Annaliza over 5 years ago
I have the same question as with this thread but it was posted 5 years ago so I created a new one.
Selection of non-visible object - Custom IC Design - Cadence Technology Forums - Cadence Community
I want to know if this is already available in options form. I am using Virtuoso 6.1.7-64b version.
Thanks a lot for the help.
Anna
    Hi Anna,
    You're using the same version as in the previous post (thanks for following the guidelines and posting this as a new thread, by the way!), but either way the enhancement I asked for has not been implemented yet. It's not been requested by anyone else, so it might help if you contact customer support and request a duplicate of CCR 1671472 to be filed on your behalf?
  • Annaliza
    Annaliza over 5 years ago in reply to Andrew Beckett
    Thank you. I will contact customer support.
    I was asking because I needed a way to easily turn ON/OFF the option.
    For the mean time, is there a way to easily change the settings from envSetVal("layout" "viaSelectionMode" 'cyclic "useCutLayers") back to envSetVal("layout" "viaSelectionMode" 'cyclic' "ignoreLayers")?
    There are times I still need to select stacked VIAs automatically even if I don't have all VIA types visible & selectable in the palette.
    Thanks a lot!
    Anna
    Andrew Beckett over 5 years ago in reply to Annaliza
    Hi Anna,
    You could create a function like this and put it in your .cdsinit:
    procedure(AnnaToggleUseCutLayers()
        case(envGetVal("layout" "viaSelectionMode")
          ("ignoreLayers" "useCutLayers")
          ("useCutLayers" "ignoreLayers")
          (t "ignoreLayers")
    hiSetBindKey("Layout" "ShiftCtrl<Key>C" "AnnaToggleUseCutLayers()")
    Then shift-ctrl-C would toggle the setting. Note that there are strictly speaking 3 settings for useCutLayers, so this is assuming you only want to toggle between two of them.
  • Annaliza
    It is working. Thank you very much for your help. I already submit ticket to cadence.
    Anna
