  3. Get the points selected by mouse of the stretch for pat...
  • Replies 18
  • Views 22564
Get the points selected by mouse of the stretch for pathSeg
Leonardo Vinci
Leonardo Vinci over 5 years ago
For getting coordinates of pathSeg, I used geGetSelSetFigPoint(shapeId), but this only returns (t nil) or (nil t) based on pathSeg's beginPt and endPt selected.
But let suppose I have a horizontal metal pathSeg. And for stretching, I am selecting the right side of this horizontal metal pathSeg to be stretched, how should I get the coordinates of the selected side(right side in this case) of this metal irrespective of its beginPt or endPt.
Also, I dont know wheather the user will select the left coordinate or right coordinate of the pathSeg, so basically I need coordinates of selected side of stretch command.
Leo
    Leo, I think I misinterpreted your previous post. I think you want this: selectedPoints=foreach(mapcan (sel pt) geGetSelSetFigPoint(shapeId) list(shapeId~>beginPt shapeId~>endPt) sel && list(pt)) …
  • skillUser
    skillUser over 5 years ago in reply to Leonardo Vinci +1
    In addition to what Andrew said and shared, there is a function "nearlyEqual()" in the newer versions of Virtuoso that makes it easier to compare floating point numbers (with a tolerance): nearlyEqual…
    Andrew Beckett over 5 years ago in reply to Leonardo Vinci +1
    Leonardo Vinci said: So can I use this approximation : (y1-y2)<0.0001 approximation if I have 2000DBUperUU? Yes, that's reasonable. nearlyEqual is another possibility as Lawrence suggested, but you still…
    Yes, that's reasonable. nearlyEqual is another possibility as Lawrence suggested, but you still really need to think about the right tolerances to use then. Note that the difference is not about decimal places, it's about significant digits. So you don't want to go for too small a tolerance because then you might hit the limit at the upper end, but practically you're not going to hit that since the maximum coordinate with 2000DBUPerUU is just over 1 metre. So either 0.0001 or 0.00001 would be fine.
  • Leonardo Vinci
    Leonardo Vinci over 5 years ago in reply to Andrew Beckett
    Many thanks Andrew Beckett and this solved my problem. :-)
  • Leonardo Vinci
    Leonardo Vinci over 4 years ago in reply to Andrew Beckett
    Hi Andrew Beckett For the "path" this code is not working and its giving me coordinates of both end points. How can I get the coordinates of only the selected side irrespective whether its a "path" or "pathSeg"?
    Leo
    Andrew Beckett over 4 years ago in reply to Leonardo Vinci
    If the object was a path, then this will return either nil, (nil) or (nil nil) depending on whether the first and/or second points are selected. It can't return the coordinates because path objects don't have a beginPt or endPt attribute.
    If you want it to work for a path too, then it would be
    selectedPoints=foreach(mapcan (sel pt) geGetSelSetFigPoint(shapeId) shapeId~>points || list(shapeId~>beginPt shapeId~>endPt) sel && list(pt))
    This first looks for a points attribute, and if that's present it uses that. If not it assumes there is a beginPt or endPt attribute.
    The code is being a bit lazy by not checking the objType of the object and doing the right thing - so this only really makes sense if it's a path or a pathSeg (it will also work for a polygon and various boundary objects too, since they also have a points list),
  • Leonardo Vinci
    This is again giving me coordinates of both the sides and not the selected side coordinate.
    Leo
    Presumably both sides are selected then. I cannot see how it can happen otherwise.
  • Leonardo Vinci
    I am selecting one side only but it gives me the whole points list of the path ie ((x1 y1) (x2 y2)) but I want the points which I selected d by mouse.
    Actually I have written a code which works with only pathSeg and now wants to make it work for path too. But I don’t want to write the whole code again, and hence am trying to find a way to convert the path to pathSeg and then run the rest of the code as it is.
    I am running leConvertShapeToPathSeg() command(over selected shapes) to convert a path to pathSeg and then require the coordinates of the selected side of this converted pathSeg.
    But when I am running this convert command, it seems the dbID of this path changes(as now it became a pathSeg) and also it breaks my selection with mouse which I selected and now the whole shape(conveted pathSeg shape) is selected and not the side which I selected earlier, and because of this the further code(which wants the mouse selected side coordinates of pathSeg as input) is not running.
    That was a rather important piece of information that you didn't mention! Normally if you use leConvertShapeToPathSeg() it doesn't leave the result selected at all, let alone only partially selected.
    I suspect it would be worth expanding your code to deal with the paths natively, but an alternative could be to use this code that I just wrote which wraps around leConvertShapeToPathSeg, preserving the selected vertices of the resulting shapes (it also returns the list of new pathSegs):
    ; Convert a path to a list of pathSegs, keeping the selected points
    ; the same as before
    procedure(CCFpathToPathSeg(@optional (path car(geGetSelSet())))
      let((selPoints newPathSegs)
        selPoints=geGetSelSetFigPoint(path)
        newPathSegs=leConvertShapeToPathSeg(path)
        foreach(map (objs points) newPathSegs selPoints
          geSelectFigPoint(car(objs) list(car(points) cadr(points)))
        newPathSegs
