  3. Get the points selected by mouse of the stretch for pat...
  • Replies 18
  • Views 23068
Get the points selected by mouse of the stretch for pathSeg
Leonardo Vinci
Leonardo Vinci over 5 years ago
For getting coordinates of pathSeg, I used geGetSelSetFigPoint(shapeId), but this only returns (t nil) or (nil t) based on pathSeg's beginPt and endPt selected.
But let suppose I have a horizontal metal pathSeg. And for stretching, I am selecting the right side of this horizontal metal pathSeg to be stretched, how should I get the coordinates of the selected side(right side in this case) of this metal irrespective of its beginPt or endPt.
Also, I dont know wheather the user will select the left coordinate or right coordinate of the pathSeg, so basically I need coordinates of selected side of stretch command.
Leo
    Leo, I think I misinterpreted your previous post. I think you want this: selectedPoints=foreach(mapcan (sel pt) geGetSelSetFigPoint(shapeId) list(shapeId~>beginPt shapeId~>endPt) sel && list(pt)) …
  • skillUser
    skillUser over 5 years ago in reply to Leonardo Vinci +1
    In addition to what Andrew said and shared, there is a function "nearlyEqual()" in the newer versions of Virtuoso that makes it easier to compare floating point numbers (with a tolerance): nearlyEqual…
    Andrew Beckett over 5 years ago in reply to Leonardo Vinci +1
    Leonardo Vinci said: So can I use this approximation : (y1-y2)<0.0001 approximation if I have 2000DBUperUU? Yes, that's reasonable. nearlyEqual is another possibility as Lawrence suggested, but you still…
    Leo,
    That will be a list of whichever points were selected (so if only one end is selected, it will be a list of one point)
  • Leonardo Vinci
    Leonardo Vinci over 5 years ago in reply to Andrew Beckett
    Yes That's what I wanted. Thanks!
    Also, below is copied sequentially from CIW window :
    nth(0 a)
    (1.8115 1.013)
    nth(0 b)
    (1.8115 1.013)
    nth(0 a)==nth(0 b)
    nil
    Why the last 1 is getting returned nil, it should be t.
    I tried using car also but the last command is giving me nil output, i don't know why could this be happening.
    Leo
    This almost certainly depends on where a  and b came from. You've probably got some small floating point rounding error in a computation somewhere. If the numbers both came out of the database, they should match. If you do:
    xy1=car(a)
    xy2=car(b)
    xCoord(xy1)-xCoord(xy2) ; what does this output?
    yCoord(xy1)-yCoord(xy2) ; what does this output?
    Performing == checks on floating point numbers is dangerous (see gazillions of issues related to this all over the internet in any programming language that uses IEEE floating point representation, such as C, python, SKILL, etc etc)...
  • Leonardo Vinci
    a and b both are list of coordinates formed from either bBoxes or beginPt and endPt of many pathSeg.
    xCoord(xy1)-xCoord(xy2) gives me 0.0
    yCoord(xy1)-yCoord(xy2) gives me 0.0
    Leo
    So xCoord(xy1)==xCoord(xy2) and yCoord(xy1)==yCoord(xy2) should both be t, and hence I would expect xy1==xy2 to be t as well. Is that what you see?
  • Leonardo Vinci
    Yes. They are true, but the lists which I am working with, are made up of several floating point numbers(upto 4 decimal places), even though I see their car(a) is same as car(b), but when I compare them with ==, it gives me nil, and because of this my next if loop is not starting.
    So how should I compare these floating point numbers.
    Leo
    If they genuinely all came from beginPt and endPt, then they should be identical, because the database itself is really integer - and gets consistently converted to floating point by dividing by the DBUPerUU value for the database.
    In general, floating point numbers should be compared with a tolerance - here's an example (there are many more on this forum)
  • skillUser
    nearlyEqual(
      n_val1 n_val2
      [f_relTolerance [f_absTolerance]]
         => t / nil
  • Leonardo Vinci
    In some place when I am subtracting the two car, the result is 2.220446e-16. So can I use this approximation : (y1-y2)<0.0001 approximation if I have 2000DBUperUU? I think the difference is not felt upto 15th decimal place, then I would go for (y1-y2)<0.00001 (upto 5th decimal place to be safe).
    Actually Why this difference is coming I have to understand, one list is of bbox and other list is of beginPt/endPt. Even though they look equal, but still getting a difference of 2.220446e-16 in someplaces not all.
    Leo
  • Leonardo Vinci
    Leonardo Vinci over 5 years ago in reply to skillUser
     yes I saw this function when I was looking at equal function. I think I have to use this function now since I am dealing with floating points upto 4 decimal places, have to introduce some approximation. Thanks.
    LEo
