  3. how to grep and print which only those output which selected...
  • Views 10900
how to grep and print which only those output which selected in combobox
saurabh96
saurabh96 over 5 years ago
Hello Guys,
i have a test-case...in which a combo box has multiple rules..say-
res_abc_1
cap_xyz_2
diode_kfb_3
mos_qwe_4
bjt_axd_5
Now when user runs above rules, chk.txt file creates. .where the output of these runs stored as-;;;;;;;;;;  chk.txt files will stores the old output for above rule status..inspite user has not selected that rule for run ;;;;;;;;;;;;;;;
res_abc_1- completed
cap_xyz_2- uncompleted
diode_kfb_3 -completed
mos_qwe_4-uncompleted
bjt_axd_5-uncompleted
i have tried this way--
rules_check = buildString(
foreach(mapcar entry form->rules->value
car(parseString(entry))
if(system(strcat("grep -q '" "%s unsuccessful" "' " rules_check chk.txt))==0 then          ;;;;;;;;;;;;;;;;;;;;;;;am gettign error how to correct grep and print the rules which is unsuccessful .
hiDisplayAppDBox( ?name 'errorbox2 ?dboxBanner "ERROR" ?dboxText "Atleast one check is Unsuccessful...Please check file" ?buttonLayout 'Close ?buttons 'Cancel)
fprintf(errport "Atleast one check is Unsuccessful!...Please check file in pwd for details info with timestamps\n" )
My question is that if i select only rule5 and rule2 from combo box and that  rule selected is uncompleted in chk.txt file. .then it should print the message ..like "rules 2,5 are uncompleted"          ..it will look only for that rule which is selected by user in chk.txt file.
How to make that it will only look at rules in chk.txt file which is selected by user in comb box??
