  3. Unexpected Skill behaviour with disembodied property li...
  • Subscribers 150
  • Views 6098
Unexpected Skill behaviour with disembodied property lists
FormerMember
FormerMember over 5 years ago
I encountered a strange behaviour with disembodied property lists, which I do not understand. When I load the following script
procedure( proc1()
   let((x)
      x = '( nil ) ; empty disembodied property list
      printf("Value should be '(nil)' and is '%A'\n" x)
      x->prop = 0
      printf("Value should be '(nil 'prop 0)' and is '%A'\n" x)
and call the procedure twice with 'proc1() proc1()' in the CIW, I get the following output:
Value should be '(nil)' and is '(nil)'
Value should be '(nil 'prop 0)' and is '(nil prop 0)'
Value should be '(nil)' and is '(nil prop 0)'  <-- x has a wrong value
After the first call of 'proc1' the values of 'x' are as expected, but in every subsequent call 'x' still has the same value, even though it is in a local let scope and initialized to '(nil). When I replace "x = '( nil )" with "x = ncons(nil)" in the procedure, it behaves as expected.
Can someone explain this behaviour or what I am doing wrong? I thought a disembodied property list can be initialized as a non-empty list with a single element (usually 'nil')?
Best regards
Paul
  • AaronSymko
    AaronSymko over 5 years ago
    When a static list or DPL is used in a function, it is scoped globally. Thus any destructive operation (e.g. x->prop = 0) will apply to the same, global object.  The solution is to use the list() function instead of '().  The list() function will construct a new list every time.  For example:
    procedure( proc1()
       let((x)
          x = list( nil ) ; empty disembodied property list
  • FormerMember
    FormerMember over 5 years ago in reply to AaronSymko
    Thanks Aaron for the answer. I guessed something like that, but could not reproduce it in the CIW. When I execute the following
    x = '(nil)
    y = '(nil)
    eq(x y) -> nil
    the lists are different objects. Is this behaviour somewhere documented? I could not find it in the Skill manual.
    Best regards
    Paul
  • AaronSymko
    AaronSymko over 5 years ago in reply to FormerMember
    The reason why it works in your experiment is because you have separate invocations of '(nil) and so they are different from each other. When called within a function, they are the same literal list. There are a couple of relevant articles which cover this (both written by Andrew Beckett):
    Why does my SKILL function remember previous local disembodied property lists?
    Copies of disembodied property lists still have links to each other
