  3. ddsSyncWithForm does not sync lib/cell/view to GUI when...
  • Views 2136
ddsSyncWithForm does not sync lib/cell/view to GUI when executing via IPC channel
lcheng
lcheng over 5 years ago
I have a function to pop up a GUI for user to select the lib, cell and view.
In the GUI there is a 'Browse' button that will run 'ddsSyncWithForm' and pop up the Library Browser for user to select.
I expect that when the user select something on Library Browser, 'ddsSyncWithForm' will sync the selection back to my GUI.
But it seems if the command to pop up the GUI dialog comes from the IPC channel, the sync behavior does not work.
The SKILL codes I tested is as following:
My_browse() is the function to pop up my customized GUI with 'Browse' button. It works when calling from Virtuoso CIW directly.
My_browse_from_ipc() is the function to invoke an external process 'test_ipc.sh'. The 'test_ipc.sh' will send (My_browse) back to Virtuoso via IPC channel. In this situation the sync behavior does not work.
;;; test.il start
procedure(My_browse()
prog((promptFd libNameFd cellNameFd viewNameFd browseButtonFd dlg)
    promptFd = hiCreateLabel(
        ?name 'promptFd
        ?labelText "Open layout cell INV_0"
    libNameFd = hiCreateStringField(
        ?prompt "Library Name:"
        ?name 'libNameFd
        ?editable t
    cellNameFd = hiCreateStringField(
        ?prompt "Cell Name:"
        ?name 'cellNameFd
        ?defValue "INV_0"
        ?editable t
    viewNameFd = hiCreateStringField(
        ?prompt "View Name:"
        ?name 'viewNameFd
        ?defValue "layout"
        ?editable t
    browseButtonFd = hiCreateButtonBoxField(
        ?name 'browseButtonFd
        ?prompt " "
        ?choices '(" Browse ")
        ?callback list("ddsSyncWithForm(hiGetCurrentForm() 'browse 'libNameFd 'cellNameFd 'viewNameFd)")
    dlg = hiCreateAppForm(
        ?name 'My_dlg
        ?formTitle sprintf(nil "Specify %s cell" "layout")
        ?fields list(promptFd libNameFd cellNameFd viewNameFd browseButtonFd)
        ?callback "My_cb(hiGetCurrentForm())"
        ?unmapAfterCB t
        ?dialogStyle 'modal
        ?buttonLayout 'OKCancel
    hiDisplayForm(dlg)
procedure(My_cb(theForm)
    hiSetCallbackStatus(theForm t)
    ddsEndSyncWithForm()
    t
My_test_pid = nil
procedure(My_test_input_handler(pid data)
    printf("(pid: %d) - '%s'" pid data)
procedure(My_test_error_handler(pid data)
procedure(My_test_stop_handler(pid status)
    printf("(pid: %d) - stopped" pid)
procedure(My_browse_from_ipc()
    My_test_pid = ipcSkillProcess(
        "./test_ipc.sh"
        "My_test_input_handler"
        "My_test_error_handler"
        "My_test_stop_handler"
        4
        5
    ipcWaitForProcess(My_test_pid)
;;; test.il end
## test_ipc.sh start
#!/bin/bash
echo '(My_browse)' >&4
sleep 20
exit 0
## test_ipc.sh end
Does anyone try this before?
If so could you help to point me if anything is wrong.
Wei
    Hi Wei,
    This is a quirk due to (I think) interactions with the event loop - essentially the issue is that the SKILL function launched by the IPC process doesn't return, and this causes it not to be able to handle the updates to the form. I've not looked into the precise details of why this is happening, but it's easily worked around by adding ?dontBlock t to the hiCreateAppForm call. The UI itself still blocks (because it's modal), but the hiDisplayForm returns immediately, which allows the call to My_browse to return too.
  • lcheng
    lcheng over 5 years ago in reply to Andrew Beckett
    Thanks a lot for your information. The solution of "?donBlock t" work well on IPC process!
    Wei
