  3. Callback when form is updated
  • Views 12178
patschouly
patschouly over 5 years ago
is there a way to get notified when a form is updated? I need to perform some actions upon changed data in a custom form, similar to the "Create Instance" dialog in layout.
Thanks.
    Each field creation function has a ?callback argument which specifies a callback to be called when that field changes (note that it's when the field changes and the focus moves out of that field). There's also the ?modifyCallback which gets called when any change is made (most of the time that's too early as you'd be checking as every change is made during typing in a field).
  • patschouly
    patschouly over 5 years ago in reply to Andrew Beckett
    Thanks Andrew, I thought there might be an option which includes all fields automatically (a general form-is-modified-callback), but this works of course fine.
