  3. empty file while when exporting netlist cdl
  • Views 11358
saurabh96
saurabh96 over 5 years ago
Hello guys,.. i have few doubts..mentioned below...
for above gui,
Now when user selects cell view then it should export the  cdl netlist for the cell select from libraray manager-       ;;;;;;;;;;;;;;;;;;cell view is lib name and topcell is cell name
procedure(CCSRunNetlisterCell(cell_check cell_top viewName runDir simulatorName)
let( ( op runDirPath singleFile mvFile )
cell_check = form->cell_view_Entry->value
cell_top = form->Topcell->value
runDirPath=strcat(runDir "/" cell_top)
simInitEnvWithArgs(runDirPath cell_check cell_top viewName simulatorName nil)
op=outfile(strcat(runDirPath "/si.env") "a")
fprintf(op "incFILE=\"\" \n")
fprintf(op "setEQUIV=\"\" \n")
close(op)
netlist()
mvFile=sprintf(nil "mv -f ./%s/netlist ./%s/%s.cdl" runDirPath runDirPath cell_top)
singleFile=sprintf(nil "cat ./%s/%s.cdl >> ./%s/netlist.cdl" runDirPath cell_top runDir)
system(mvFile)
system(singleFile)
printf("Netlisting the cell:%L from Library:%L in the path:%L\n" cell_top cell_check runDirPath)
) ; let
) ;procedure
CCSRunNetlisterCell("%s" "%s" "schematic" "CDL" "auCdl" cell_check cell_top)
netlist = simplifyFilename(strcat(runDirPath "/" celltop ".cdl")
for above am getting error as max argument can be called 5 ...............in this how can i call arguments as it may keep changing as per user
