  3. Adding menu to maestro
  • Views 13295
dragank
dragank over 5 years ago
Hi all.
I am using IC6.1.8-64b.500.10
Here is procedure that i am trying to use for adding new menu item to maestro:
procedure( InternalMaestroAddMenu(@rest args)
let( (item11 item12 item21 item22)
item11 =
hiCreateMenuItem(
?name 'item11
?itemText "Corners plotter"
?callback "setupSignalPlotter()"
item12 =
hiCreateMenuItem(
?name 'item12
?itemText "Monte Carlo plotter"
?callback "setupMonteCarloPlotter()"
item21 =
hiCreateMenuItem(
?name 'item21
?itemText "Sample outputs"
?callback "setupSampleOutputs()"
item22 =
hiCreateMenuItem(
?name 'item22
?itemText "MAV postprocessing"
?callback "setupMAVFilterOutputs()"
item23 =
hiCreateMenuItem(
?name 'item23
?itemText "CoI postprocessing"
?callback "setupCoIFilterOutputs()"
samplerMenu = hiCreatePulldownMenu(
'samplerMenu
"Sampling"
list(
item21
item22
item23
plotterMenu = hiCreatePulldownMenu(
'plotterMenu
"Plotting"
list(
item11
item12
sliderPlot = hiCreateSliderMenuItem(
?name 'sliderPlot
?itemText "Plotters"
?subMenu plotterMenu
sliderSample = hiCreateSliderMenuItem(
?name 'sliderSample
?itemText "Sample"
?subMenu samplerMenu
mainAddonMenu = hiCreatePulldownMenu(
'mainAddonMenu
"Sampling and Plotters"
list( sliderSample sliderPlot )
hiInsertBannerMenu(hiGetCurrentWindow() mainAddonMenu 0)
So far I am getting error in CIW
*Error* append: argument #1 should be a list or another acceptable type - t
And there is only this new menu item. Common items are not present.
Should this procedure be written differently?
Thank you in advance
Dragan
  • mbracht
    mbracht over 5 years ago
    Hi Dragan,
    I don't see any call to append() in this code above - maybe it's in one of your callbacks.
    The error message itself is pretty clear, the first argument of append (and also the second one) must be a list which in your case it obviously isn't.
    Max
  • dragank
    dragank over 5 years ago in reply to mbracht
    Only callbacks i have are for adding to menu:
    deRegUserTriggers("maestro" nil 'InternalMaestroAddMenu)
    deRegUserTriggers("explorer" nil 'InternalMaestroAddMenu)
    deRegUserTriggers("adexl" nil 'InternalMaestroAddMenu)
    Andrew Beckett over 5 years ago in reply to dragank
    Your menu callback is incorrect. User menu callbacks (registered with deRegUserTriggers) should not add the menus themselves. Instead they should return a list of pulldown menus and "de" (Design Editor) takes care of adding them into the banner menus for you.
    So replace the line:
    with:
    list(mainAddonMenu)
    The error is because it's trying to add the return value of hiInsertBannerMenu - which isn't a list - and hence the error.
  • dragank
    dragank over 5 years ago in reply to Andrew Beckett
    Thank You Andrew.
    It is working now.
