  3. problems in creating si.env
  • Views 13855
saurabh96
saurabh96 over 5 years ago
Hello folks,
one strange behavior is observed while creating netlist cdl file...when am creating si. Env file. am running the script through GUI after run completes.. SIM cell name is coming Null.
after that , when am closing my gui...CIW struck for few seconds and si.env file gets updated..and this time... simLibName comes NULL.
below code am using.
lib_view_Label=hiCreateLabel(
?name 'lib_view_Label
?labelText "Library Name*"
?justification 'left
lib_view_Entry=hiCreateStringField(
?name 'lib_view_Entry
?enabled nil
?callback "runCDLout(hiGetCurrentForm())"
cellLabel=hiCreateLabel(
?name 'cellLabel ?labelText "Cell Name*"
Topcell=hiCreateStringField(
?name 'Topcell
?value ""
browse=hiCreateButton(
?name 'browse
?buttonText "Browse..."
?callback "(ddsSyncWithForm (hiGetCurrentForm) 'browse 'lib_view_Entry 'Topcell )"
procedure(runCDLout(form)
printf("%s %s" form->lib_view_Entry->value form->Topcell->value)
prog(
(op id )
;;create si.env file
op = outfile("./si.env" "w");
fprintf(op sprintf(nil "simLibName = \"%s\" \nsimCellName = \"%s\" \n" form->lib_view_Entry->value form->Topcell->value))
fprintf(op "simViewName = \"schematic\" \n")
fprintf(op "simSimulator = \"auCdl\" \n")
fprintf(op "simNotIncremental = nil\n")
fprintf(op "simReNetlistAll = 't\n")
fprintf(op "simViewList = '(\"auCdl\" \"schematic\" \"symbol\")\n")
fprintf(op "simStopList = '(\"auCdl\")\n")
fprintf(op "hnlNetlistFileName = \"%s.cdl\"\n" form->Topcell->value)
fprintf(op "resistorModel = \"\"\n")
fprintf(op "shortRES = 2000.0\n")
fprintf(op "preserveRES = 't\n")
fprintf(op "checkRESVAL = 't\n")
fprintf(op "checkRESSIZE = 'nil\n")
fprintf(op "preserveCAP = 't\n")
fprintf(op "checkCAPVAL = 't\n")
fprintf(op "checkCAPAREA = 'nil\n")
fprintf(op "preserveDIO = 't\n")
fprintf(op "checkDIOAREA = 't\n")
fprintf(op "checkDIOPERI = 't\n")
fprintf(op "checkCAPPERI = 'nil\n")
fprintf(op "simPrintInhConnAttributes = 'nil\n")
fprintf(op "checkScale = \"micron\"\n")
fprintf(op "checkLDD = 'nil\n")
fprintf(op "pinMAP = 't\n")
fprintf(op "preserveBangInNetlist = 'nil\n")
fprintf(op "shrinkFACTOR = 0.0\n")
fprintf(op "globalPowerSig = \"\"\n")
fprintf(op "globalGndSig = \"\"\n")
fprintf(op "displayPININFO = 't\n")
fprintf(op "preserveALL = 't\n")
fprintf(op "setEQUIV = \"\"\n")
fprintf(op "incFILE = \"\"\n")
fprintf(op "auCdlDefNetlistProc = ansCdlSubcktCall")
fprintf(op "incFILE=\"\" \n")
fprintf(op "setEQUIV=\"\" \n")
close(op)
id = ipcBeginProcess("si -batch -command netlist");
ipcWait(id);
;system("si -batch -command netlist > si.log");
);end prog
Please Guide what the error and how i can correct it.
Thanks in advance!
    The code as you've provided it can't work, because the library name is disabled, and so the browse button doesn't work. So inevitably the simLibName will end up blank. If I change the ?enabled on the lib…
    The code as you've provided it can't work, because the library name is disabled, and so the browse button doesn't work. So inevitably the simLibName will end up blank.  If I change the ?enabled on the lib name field to t, then the callback works.
    This is almost certainly something to do with where you're calling the function from - that's unclear since you've not included any code that actually invokes runCDLout.
  • saurabh96
    saurabh96 over 5 years ago in reply to Andrew Beckett
    Thanks Andrew.
    it was solved!!
    regards,
