  3. How to use ddsSyncWithForm and procedure in call back f...
  • Views 12099
How to use ddsSyncWithForm and procedure in call back function
saurabh96
saurabh96 over 5 years ago
Hello everyone,
i have made library string field and browse button through cell user can selects library and cell name.
as user clicks browse option library window opens , user selects lib and cell and close the window ...now i want as soon user press close button on lib window then procedure starts to run.
lib_view_Label=hiCreateLabel(
?name 'lib_view_Label
?labelText "Library Name*"
?justification 'left
lib_view_Entry=hiCreateStringField(
?name 'lib_view_Entry
?enabled nil
cellLabel=hiCreateLabel(
?name 'cellLabel ?labelText "Cell Name*"
Topcell=hiCreateStringField(
?name 'Topcell
?value ""
browse=hiCreateButton(
?name 'browse
?buttonText "Browse..."
?enabled nil
?callback "(ddsSyncWithForm (hiGetCurrentForm) 'browse 'lib_view_Entry 'Topcell )"             ;;;;;;;;;;;;;;;i want that when user selects lib and cell and as closes the lib window runout procedure gets start
"runout(hiGetCurrentForm())"
how to sync both above?
thanks in advance
    Normally you'd trigger some action on the form by having a callback on the form itself (i.e. the hiCreateAppForm/hiCreateLayoutForm) and then the OK/Apply button would trigger the action. There isn't…
    There isn't a specific callback for when the library browser has been closed, but you could (if you really wanted it to work this way) use a callback on the lib_view_Entry and Topcell fields which would then get fired when either of these changed. This would be triggered when you either type in a new value on the form, or select something in the linked library browser. You would probably need to have your callback check that neither of the two fields was blank (e.g. using blankstrp() or just ==""), but personally I think this would be a strange use model as if somebody mis-clicked something in the browser, it would run automatically - which is unlikely to be desired.
    Better to have an explicit action - either the OK/Apply on the form, or an additional button on the form.
  • saurabh96
    saurabh96 over 5 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thanks for a response..above issue has been solved previously
    srv
