  3. SKILL function to get spec column of meastro test outpu...
  • Views 13140
SKILL function to get spec column of meastro test output
riteshSW
riteshSW over 5 years ago
Maestro test view has a output tab which lists the outputs in a table format. The table has columns Name, Type, Description, Plot, Save, and Spec. I am interested in the last column, Spec.
How do I get value of the spec for a given output in SKILL?
I can get list of outputs in a maestro test by doing something like this. But the output objects don't have any property for spec.
 maeOpenSetup(libraryName cellName viewName ?mode "r")
testSession = maeGetTestSession(testName)
outputs = asiGetOutputList(testSession)
    You could use maeGetTestOutputs() to get the list of outputs rather than the two-step approach you've used. To get the details of a spec, you can do: maeSess=maeOpenSetup(libraryName cellName viewName…
    maeSess=maeOpenSetup(libraryName cellName viewName ?mode "r")
    sdb=axlGetMainSetupDB(maeSess)
    specInfo=axlGetSpecData(sdb "resultName" "testName")
  • riteshSW
    riteshSW over 5 years ago in reply to Andrew Beckett
    Thanks Andrew! axlGetSpecData works. I tried maeGetTestOutps() and that worked too.
