  3. Load Corners CSV File SKILL Function
  • Views 12217
Curtisma
Curtisma over 5 years ago
Hello:
Could someone point me to a SKILL function for loading corners CSV file into a Maestro view?
The only function we found, maeLoadCorners, seems to only support the sdb (XML) corners file format.
In the Maestro gui, however, you have the option of saving and loading the corners as a CSV file. The CSV format is a lot more human-readable than the XML version so we'd prefer to use it instead.
We're using IC6.1.8-64b.500.15
-Curtis
    Curtis, This was asked for by many people, and was added in IC6.1.8 ISR19 (so IC6.1.8-64b.500.19). The maeLoadCorners function now accepts CSV files too (I just tested it, admittedly in ISR20, but as…
    Curtis,
    This was asked for by many people, and was added in IC6.1.8 ISR19 (so IC6.1.8-64b.500.19). The maeLoadCorners function now accepts CSV files too (I just tested it, admittedly in ISR20, but as far as I can see it should be in ISR19 too; ISR20 is the current version). It's in the documentation as well.
  • Curtisma
    Curtisma over 5 years ago in reply to Andrew Beckett
    Thanks Andrew! I'll try it out on the newer version.
