  3. Q about ERROR (ADE-2243)
  • Views 12364
Weijie JIang
Weijie JIang over 5 years ago
Dear,
I sometimes get the following error which spams all the time
ERROR (ADE-2243): Failed to check the available disk space for the /tmp database in the
Could anyone tell me how to resolve this kind of problems?
Weijie
    Andrew Beckett over 5 years ago in reply to Weijie JIang +1
    That's newer than the version I thought had the fix, but it's still pretty old (the current version is ICADVM20.1-64b.500.20 - the version you have is over 3 years old). It's possible it's been fixed in…
    Weijie,
    Which version are you using? (Help->About - please report the entire version number, not just the bit at the beginning). I believe this was fixed some time ago (from what I can see from CCR 1751872, it was fixed in IC6.1.7.500.14), but I'm not sure what exactly you're being or whether it's the same issue (after all, I think the error message now says either EXPLORER-2243 or ASSEMBLER-2243 not ADE-2243), which suggests to me you're using an old version.
    You might be able to work around it by using:
    envSetVal("maestro.results" "RDBCreatePolicy" 'cyclic "NFSDisk")
    in your .cdsinit. There's another option to reduce the disk quota size, but if it's failing to check the disk quota, I don't think that's the issue.
  • Weijie JIang
    Weijie JIang over 5 years ago in reply to Andrew Beckett
    version ICADV12.3-64b.500.21. This is the latest version in my lab.
    That's newer than the version I thought had the fix, but it's still pretty old (the current version is ICADVM20.1-64b.500.20 - the version you have is over 3 years old). It's possible it's been fixed in the meantime, so it would be wise to check with the latest version - and if it still occurs, contact customer support.
    Did you try my suggested workaround? Note that this turns off what would normally give a performance improvement, so the best would be to move to a fixed version or contact support if not fixed in the latest version.
