  3. Need to highlight a net in layout using Skill
  • Views 13563
BabaiVLSI
BabaiVLSI over 5 years ago
Need to highlight a net in the layout using Skill. Also would like to customize the result of the highlight by selecting specific metal & VIA layers in the script.
  • ebecheto
    ebecheto over 5 years ago
    The function you are looking for is lntAddTrace
    Also it requires Layout XL license to load i think. Here below an example to compile many pictures into one gif extracted for a layout view. Highlighting A<1> B<1> C<1>
    ; while viewing BLOC layout win = hiGetCurrentWindow();=> window:25 colors='("blue" "purple" "red" "orange"  "lime"  "magneta" "pink" "yellow" "cyan")
    ia=308 j=-151 k=457 pattern="mv60_" pin2probe(list(sprintf(nil "A_%d" ia+imv) sprintf(nil "B_%d" j+imv) sprintf(nil "C_%03d" k+imv))) defun(pin2probe (@optional (pinList list("A_18" "B_0" "C_17") )) lntRemoveAllTraces() foreach(mapcar i linRg(0 length(pinList)-1 1);=> (0 1 2) lntAddTrace(win nth(i pinList) ?hilightColor nth(i colors)) ) geRefresh()) for(imv 0 291 names=list(sprintf(nil "A_%d" ia+imv) sprintf(nil "B_%d" j+imv) sprintf(nil "C_%03d" k+imv)) lntRemoveAllTraces() pin2probe(names) filename=sprintf(nil "%s%03d.png" pattern imv) hiWindowSaveImage(?target win ?path filename ?centralWidget t) ) sh(sprintf(nil "convert -delay 5 %s* -layers OptimizeTransparency +map gif_%s.gif" pattern pattern )) sh(sprintf(nil "animate gif_%s.gif&" pattern))
    Hope it helps,
  • ebecheto
    ebecheto over 5 years ago in reply to ebecheto
    I have discovered that lntAddTrace uses a default constraint group that track the nets trouhgh the polysilicium GATE of the transistor. That can highlight unwanted path (not knowing if it's an open or closed transistor :)
    so you probably wants to change the constraint group to another one : example
    win=getCurrentWindow();=> window:91
    cv=geGetWindowCellView();=> db:0x46c4161a
    techFile = techGetTechFile(cv)
    cstG=car(setof(c techFile~>constraintGroups c~>name=="virtuosoDefaultSetup"));=> cst:0x2371bf1d
    ;or
    cstG = cstFindConstraintGroupIn(techFile "virtuosoDefaultSetup");=> cst:0x2371bf1d
    validLayers=car(setof(o cstG~>objects o~>defName=="validLayers"));=> cst:0x2371ba9d
    validLayers~>??;=> (cst:0x2371ba9d tech db:0x2371c99a cellView nil objType "simpleConstraint" name "C__3" defName "validLayers" layers nil
    value ("TOP_M" "TOP_V" "M5" "V5" "M4" "V4" "M3" "V3" "M2" "V2" "M1") params nil hard t ID nil description nil)
    ; default Layout XL constraintGroup == "virtuosoDefaultExtractorSetUp" lntAddTrace(win sprintf(nil "Y<%d>" 85) ?constraintGroup "virtuosoDefaultSetup") geRefresh() lntRemoveAllTraces() foreach(mapcar j linRg(0 20 1) lntAddTrace(win sprintf(nil "R<%d>" j) ?constraintGroup "virtuosoDefaultSetup"))
