  3. Utilising a Form 'Help' Callback
  • Views 3212
kdolan
kdolan over 5 years ago
I am having a little bit of confusion trying to implement a callback function for the 'Help' button in a form/GUI. I have looked at the Cadence Help documentation but I am likely not understanding it correctly. I have attached some simple code below whereby I have a form ( myImageGUI ) and I am trying to execute the myExampleHelpCB() when the user clicks the 'Help' button.
Any thoughts on where I am going wrong?
My end goal is when the user pushed the help button, it will pop up a PDF with the details relating to the specific Skill program.
Keelan
procedure(ImageExportGUI()
prog((cv cw imageView userFilePath userImageType userBGColour myImageGUI)
cv = geGetWindowCellView(hiGetCurrentWindow())
cw = hiGetCurrentWindow()
userFilePath = hiCreateStringField(
?name 'userFilePath
?prompt "File Path:"
?editable t
?value strcat(cv~>libName "_" cv~>cellName "_" cv~>viewName "_Design.png")
);hiCreateStringField
userImageType = hiCreateRadioField(
?name 'userImageType
?prompt "Image Scope: "
?choices list("Entire Design" "Visable Area")
?value "Entire Design"
);hiCreateRadioField
userBGColour = hiCreateRadioField(
?name 'userBGColour
?prompt "Background Colour: "
?choices list("Black" "White")
?value "Black"
myImageGUI = hiCreateAppForm(
?name 'myImageGUI
?formTitle "Export Image GUI"
?fields
list(
list(userFilePath 0:0 500:30 90)
list(userImageType 0:35 100:0 90)
list(userBGColour 0:70 100:0 120)
?callback "adiExportImage(myImageGUI->userFilePath->value myImageGUI->userImageType->value myImageGUI->userBGColour->value)"
?buttonLayout 'OKCancelApply
);hiCreateAppForm
putprop('myImageGUI 'myExampleHelpCB() 'hiHelpAction)
hiDisplayForm(myImageGUI)
);let
);procedure
procedure(myExampleHelpCB()
prog(
printf("\nI've made it to the help callback function!")
);prog
);procedure
    Keelan, You simply need to make the hiHelpAction a string: putprop('myImageGUI "myExampleHelpCB()" 'hiHelpAction) It either needs to be a string (which is a full expression) or a symbol 'myExampleHelpCB…
    Keelan,
    It either needs to be a string (which is a full expression) or a symbol 'myExampleHelpCB, which means that it will be passed four arguments (according to the help). Your function doesn't have any arguments, so you need to use the string approach.
  • kdolan
    kdolan over 5 years ago in reply to Andrew Beckett
    Ah yes silly me. Thanks for the help Andrew!
