  3. Weird behavior when using drGetWaveformYVec and drGetElem...
  • Views 12018
Weird behavior when using drGetWaveformYVec and drGetElem with a logic signal
radustoica
radustoica over 5 years ago
  I need to automatically process the results of some mixed-signal simulations, containing both analog and digital signals.
  I am using the drGetWaveformYVec function to get the Y values for these signals, then drGetElem to get the element values from the resulting vectors. This works ok for analog signals, but for the digital signals I see a weird behavior - the value returned by drGetElem makes no sense.
For example:
digital_voltage = v("some.logic.signal")
srrWave:0x3fa1b0d0
ymax(digital_voltage)
5.0
 yvec_digital_voltage = drGetWaveformYVec(digital_voltage)
srrVec:0x3fa5f3c0
drGetElem(yvec_digital_voltage 0)
192
Why would this happen? Is this the expected behavior? If yes, is there any possibility to check if a waveform comes from a digital signal, so that I can skip their processing?
    Yes, there's some special encoding of logic signals - the various states (0, 1, Z, X plus strength info) show up with some special numbers.
    Anyway, if you do drType(yvec_digital_voltage) or drGetWaveformYType(digital_voltage) they will return the symbol logic (so drType(yvec_digital_voltage)=='logic)
