  3. Flatten a pCell and Regroup After modification
  • Views 13432
Kevin Buck
Kevin Buck over 5 years ago
The PDK I'm using does not have the capability of removing a S/D metal and contact. I'm trying to create a standard cell library and I'd like to remove this from the device by flattening the cell and manually deleting the unwanted metal1 and contact layers. The problem I'm having is that I would like to regroup the remaining shapes and be able to define the device correspondence between schematic and layout so that it is Layout XL compliant (so when you select the device in the schematic or layout it is selected in the other view). If I try grouping the leftover shapes the group is not recognized as an instance and I'm not able to bind the schematic and layout devices. Is there a way to force the tool to recognize a group as an instance so I can do this?
    Hi Kevin,
    It would need to be an instance of some sort - so there are two approaches:
    1. Build a wrapper PCell which augments the standard PDK device by selectively removing the metal/contacts but otherwise uses the standard PDK device under the hood (this is very easy to do using the Cadence PCell Designer tool rather than writing SKILL code - contact your account team if you're interested pursuing that approach).
    2. Creating a fixed cellView for the particular modified device (so it's an instance rather than a group).
  • Kevin Buck
    Kevin Buck over 5 years ago in reply to Andrew Beckett
    Great, thank you for the reply.
