  3. Returning the Cursor Position within the Screen Area
  • Views 15089
kdolan
kdolan over 5 years ago
I want to be able to return the x:y coordinates of the cursor with reference to the screen area. Is there a way to do this?
I found similar threads using the hiGetPoint() and hiGetCommandPoint() commands, but these only return the coordinates with reference to a window.
Instead, I would like the coordinates to be with reference to the screen size [   hiGetScreenSize( )   ].
I also came across the following command and maybe it has something to do with this?   hiGetScreenPoint()
I couldn't however get this command to work.
Thanks for the help,
Keelan
    Keelan,
    hiGetScreenPoint gets the screen (pixel) coordinates but only within the drawing area of the specified window.
    There's no function to get the absolute pixel coordinate on the screen. There have been a few requests for this in the past (mostly related to trying to position a form relative to the cursor, I think), but these enhancements have not been implemented (they haven't been planned).
    Why do you need this?
  • kdolan
    kdolan over 5 years ago in reply to Andrew Beckett
    Ah I see. And the reason being is exactly as you say, trying to position a form relative to the cursor.
    I understand you can change the default location of forms, but yes I was specifically looking to position forms relative to the cursor.
    Do you know of any other strategy or workaround for such a issue? Or do I have to go back to the drawing board?
    Keelan
    Andrew Beckett over 5 years ago in reply to kdolan
    Hi Keelan,
    How about this:
    hiGetCIWindow()->formRelativeTo="currentWindow"
    hiGetCIWindow()->formPlacement="center"
    The documentation covers the other values - but the formPlacement could be left/right/top/bottom too.
    Maybe that gives you the kind of flexibility you want? There's also a similar setting for optionFormRelativeTo and optionFormPlacement. They are set as attributes on the CIW window.
  • kdolan
    Thanks for the information. I've come across this before alright but it is not exactly what I was looking for.
    I went and did a bit of further digging and found out I could get the mouse coordinates using Python and then utilising this information via Cadence.
    I've done up to following code that achieved this:
    The Cadence Script:
    procedure( getMouseCoordinates()
    prog(
    pythonScript pythonScriptProcess pythonOutput tmp mouseXpos mouseYpos
    pythonScript = "python ~kdolan/Python/getMouseCoordinates.py"
    pythonScriptProcess = ipcBeginProcess(pythonScript) ;execute my python script
    ipcWait(pythonScriptProcess) ;wait for scipt to complete
    pythonOutput = ipcReadProcess(pythonScriptProcess) ;store script output
    if(ipcIsAliveProcess(pythonScriptProcess) == t ;if child still exists
    then
    ipcCloseProcess(pythonScriptProcess) ;close child
    if(rexMatchp("Errno" pythonOutput) || rexMatchp("SyntaxError" pythonOutput)
    then
    printf("\nERROR --> [getMouseCoordinates.il] A problem occured when executing the command: %L \n", pythonScript)
    return(nil)
    rexCompile(" *")
    pythonOutput = rexReplace(pythonOutput " " 0)
    pythonOutput = parseString(pythonOutput "\n") ;format script output
    foreach(line pythonOutput ;step through each line of script output
    rexCompile(" *")
    line = rexReplace(line "" 0)
    if(rexMatchp("c_int" line) == t
    then
    tmp = parseString(line ")")
    mouseXpos = atoi(nth(1 parseString(nth(0 tmp) "("))) ;store mouse X position
    mouseYpos = atoi(nth(1 parseString(nth(1 tmp) "("))) ;store mouse Y position
    return(list(mouseXpos mouseYpos))
    The Python Script:
    import sys
    from ctypes import *
    Xlib = CDLL("libX11.so.6")
    display = Xlib.XOpenDisplay(None)
    if display == 0: sys.exit(2)
    w = Xlib.XRootWindow(display, c_int(0))
    (root_id, child_id) = (c_uint32(), c_uint32())
    (root_x, root_y, win_x, win_y) = (c_int(), c_int(), c_int(), c_int())
    mask = c_uint()
    ret = Xlib.XQueryPointer(display, c_uint32(w), byref(root_id), byref(child_id),
    byref(root_x), byref(root_y),
    byref(win_x), byref(win_y), byref(mask))
    if ret == 0: sys.exit(1)
    print child_id.value
    print root_x, root_y
