  3. I hope other nets will be opened and wiring will be done...
  • Replies 11
  • Views 16389
I hope other nets will be opened and wiring will be done automatically. Is there a script or technique that fits this?
chanho
chanho over 5 years ago
Is there a technology that doesn't work like the picture on the left and automatically works like the picture on the right?
    Andrew Beckett over 4 years ago in reply to chanho
    You seem to have edited the post above and changed it to include the description in Korean - probably not very likely to get an answer that way. Also, the code has got several mistakes in it (e.g.cv~>instnaces and inst~>trnasform. Either way, the result from dbShapeQuery will give you a list of shapes if you've specified 0 as the stop level, but with 32, each found shape will be a list describing the hierarchical path. Because of that,  filtering it to find those with the right net is not going to work because they're in the wrong cellView (and the setof won't work) and also dbLayer* functions all expect lists of shapes in the same cellView - not lists of lists of hierarchy paths down to shapes - so that would never work.
    Several things would be challenging here - identifying the net on lower level shapes is going to be tricky because the net information is local to the cellView and so the net object will be different. There are functions for doing hierarchical layer boolean operations (the abeLayerAnd/abeLayerAndNot/abeLayerSize functions for example) but you've first got to identify which set of shapes you want to operate on. That's certainly beyond what I have time to write here (especially as the requirements are not entirely clear). Perhaps you should contact customer support?
