  3. Error while running AMS sim from ADE Explorer
  • Views 11146
Yash4567
Yash4567 over 4 years ago
I am seeing the following error whenever I run AMS sim from ADE Explorer.
*Error* eval: undefined function - _axlCalcValDebugPrintf3
*Error* failed at creating netlist
How do I solve this?
    That's odd - it's a relatively new internal function that was introduced in IC6.1.8/ICADVM20.1 ISR19. The only thing I can imagine is that either you're using some engineering hotfix of an older version which maybe doesn't have one of the dependencies installed, or you have a patch loaded which also isn't intended for that version.
    Which sub-version are you using? Help->About will tell you the full name.
    Can you also do the following in the CIW and then reproduce the error?
    _stacktrace=50
    If that doesn't show anything more, then do:
    sstatus(errsetTrace t)
    and reproduce the error again? I'm hoping a stack trace will pinpoint the problem.
