  3. Setting transient simulation output infotimes programma...
  • Views 14291
Setting transient simulation output infotimes programmatically
dragank
dragank over 4 years ago
Hi all.
I am using IC6.1.8-64b.500.10
Is there away to set infotimes value from SKILL code:
Best regards,
Dragan
  • dragank
    It looks I've found it using "maeGetAnalysis(test "tran" ?includeEmpty t)"
  • dragank
    dragank over 4 years ago in reply to dragank
    No. My bad. It doesn't wotk, at least how I did it:
    analysisOpts = maeGetAnalysis(test "tran" ?includeEmpty t)
    newAnalysisOpts = list()
    foreach( ao analysisOpts
      if( eqv("infotimes" car(ao))
      then
        newAnalysisOpts = append1(newAnalysisOpts list("infotimes" infoTimes))
      else
      newAnalysisOpts = append1(newAnalysisOpts ao)
    maeSetAnalysis(test "tran" ?options newAnalysisOpts)
  • dragank
    I've found it.
    infoTimes should be list of strings.
    Best regards,
    Dragan
    Andrew Beckett over 4 years ago in reply to dragank
    Dragan,
    There is absolutely no need to do all that messing around getting all the current settings and then replacing the current value with the new and then re-applying the entire set. It's much simpler than that - simply do:
    maeSetAnalysis("mylib:myinvtb:1" "tran" ?options list(list("stop" "50n")))
    maeSetAnalysis("mylib:myinvtb:1" "tran" ?options list(list("infotimes" list("20n" "30n" "40n"))))
    Each will add or update the current settings, so there's no problem with calling maeSetAnalysis multiple times with a subset of options.
    If you're unsure as to what is expected, the easiest way is to enter it in the UI and then use maeGetAnalysis() to see what the value and parameter name was.
  • dragank
    dragank over 4 years ago in reply to Andrew Beckett
    Thank you.
    This is far more simple then I did.
    Best regards,
    Dragan
