  3. How to move specific file from one directory to another...
  • Views 15373
How to move specific file from one directory to another one
saurabh96
saurabh96 over 4 years ago
Hello Everyone,
I have netlist abc.cdl in my PWD ,ALSO
My setting file is in other directory...also setting file path differs
i want to move my abc.cdl file from PWD to above  test/info directory.
How to achieve it from skill.
    The function is renameFile()
  • saurabh96
    saurabh96 over 4 years ago in reply to Andrew Beckett
    Hello Andrew,
    thanks for suggestions...but it didn't work as i expected.
    let me explain you more clearly.
    I have setting file directory where all setting file is stored...but this path is variable .
    eg - for 40 nm  it is  ---/user/tech/40/setting/setting.file
    for 15nm --   /prog/list/15/setting.file.
    Also i selecting setting file via browse option.
    Now when i export netlist CDL using si.env and system("si -batch -command netlist");
    it is generating auCDL in my current working directory...
    I want that as soon as i set my setting file...the generated CDL moves from current working directory to respective tecg setting file direcrtory..i.e for 40nm it should go into ---/user/tech/40/setting   folder and for 15nm it should go into --  /prog/list/15/ folder.
    I hope it clears some clouds.
    Thanks in advance
    Robin
  • saurabh96
    saurabh96 over 4 years ago in reply to saurabh96
    Hi , any update on this question-
    regards,
    Robin
    Andrew Beckett over 4 years ago in reply to saurabh96
    If this is urgent, you should contact customer support. This forum is a community forum and not a substitute for support - I only answer questions in my spare time (it's not part of my job) and I was on vacation - so answering forum questions wasn't a priority. Having some downtime was.
    You didn't say why renameFile() wouldn't work (I think it should), plus if you're doing:
    presumably you could also do:
    system("si -batch -command netlist; mv netlist.cdl /user/tech/40/setting"); or whatever the CDL file you're generating is called.
    Your question was rather badly phrased, so it was very hard to know how to answer.
  • saurabh96
    Thanks for suggestions..
    system("si -batch -command netlist; mv netlist.cdl /user/tech/40/setting");  here /user/tech/40/setting is variable path
    file_Label=hiCreateLabel(
    ?name 'file_Label
    ?labelText "Set File*"
    ?justification 'left
    file_Entry=hiCreateStringField(
    ?name 'file_Entry
    ?callback "readSetFile(hiGetCurrentForm())"
    browse_set_Entry=hiCreateButton(
    ?name 'browse_set_Entry
    ?buttonText "Browse..."
    ?callback "ddsFileBrowseCB(hiGetCurrentForm() 'set_file_Entry \"\" 'fileOnly)"
    it will point to browse the  set file...
    i want that when the move netlist it should copy in that directory of above set file.
    Basically, how i can get that directory path .ie one step up from file path?
    Robin
    Robin,
    There's no built-in function to find the directory part of a file name (unfortunately) so you'd probably do something like:
    fileTailPattern=pcreCompile("/[^/]*$")
    fileName=myForm->set_file_Entry->value ; your code above seems to call the field either file_Entry or set_file_Entry, so I'm not sure which is correct
    dirName=pcreReplace(fileTailPattern fileName "" 1)
    sprintf(command "si -batch -command netlist; mv netlist.cdl %s" dirName)
    system(command)
