  3. How to create and add submenu options in virtuoso windo...
  • Views 16522
How to create and add submenu options in virtuoso window
saurabh96
saurabh96 over 4 years ago
Hello ,
am using below code to add Cadence option menu in virtuoso
setupItem = (hiCreateMenuItem
?name 'Setup
?itemText "Setup"
?callback "(println \"WELCOME TO CADENCE\") Switches()" )
Menu = (hiCreatePulldownMenu
(gensym)
"CADENCE"
(list setupItem))
(hiInsertBannerMenu window( 1 ) Menu (length (hiGetBannerMenus (window 1))) )
and its generating output as-
Now is that there way instead of appearing as new Cadence option ,its should appear as submenu under VGI option which is pre-existing?
How i can do that...when i click VGI option CADENCE menu should appear and when click on CADENCE window then setup option should appear?
How can i acheive that?
Thomas
  • mbracht
    mbracht over 4 years ago +1
    Thomas...I may have misunderstood your problem - if you want to create a sub menu you need to to this in terms of the hiCreateSliderMenuItem() function. The below code adds a sub menu (or slider menu)…
  • mbracht
    Have you tried this?
    (hiAddMenuItem <VGIMenu> setupItem)
    with <VGIMenu> being the Pulldown Menu VGI. You can get a list of all Pulldown Menus in the CIW with (hiGetBannerMenus (window 1))
    Max
  • saurabh96
    saurabh96 over 4 years ago in reply to mbracht
    Hello Max,
    Thanks for quick reply.
    Still am not getting the desired result as when am clicking VGI options ...CADENCE menu is undisplayable.
    Can you please suggest what the error and how can i correct it?
    procedure(Menu()
    let((setupItem )
    setupItem = hiCreateMenuItem(
    ?name 'Setup
    ?itemText "Setup"
    (hiAddMenuItem VGIMenuItem setupItem)
    (gensym)
    "CADENCE"
    (list setupItem))
    Thomas
  • mbracht
    mbracht over 4 years ago in reply to saurabh96
    Hi Thomas,
    I don't quit get your code - you create a menu item (setupItem) and then make a call to hiAddMenuItem specifying VGIMenuItem as first argument. In fact the first argument to hiAddMenuItem() needs to be the containing menu - the variable VGIMenuItem implies that this is a menu item though. Subsequently  you specify setupItem as a menu item in the CADENCE menu...I thought you wanted it in the VGI menu????
    Let me explain again how this works, when you create a pull down menu you can populate it with menu items at the time when you create the menu or lateron when with hiAddMenuItem(). Here is an example of a CADENCE pulldown menu that is populated with one item during it's creation and another one lateron.
    (let (item1 item2)
       item1 = (hiCreateMenuItem
                   ?name (gensym)
                   ?itemText "Click me..."
                   ?callback "(println \"ooops...I just got clicked!\")" )
       item2 = (hiCreateMenuItem
                   ?name (gensym)
                   ?itemText "Never click me!"
                   ?callback "(println \"I told you not to click me didn't I?\")")
       playMenu = (hiCreatePulldownMenu
                      (gensym)
                      "CADENCE"
                      (list item1))
       (hiAddMenuItem playMenu item2)
       (hiInsertBannerMenu window( 1 ) playMenu (length (hiGetBannerMenus (window 1))) ))
  • mbracht
    Thomas...I may have misunderstood your problem - if you want to create a sub menu you need to to this in terms of the hiCreateSliderMenuItem() function. The below code adds a sub menu (or slider menu) to the CIW options menu:
    (let (item1 item2)
                   ?name (gensym)
                   ?name (gensym)
                      (gensym)
                      "CADENCE"
                      (list item1 item2))
       slider = (hiCreateSliderMenuItem
                   ?name (gensym)
                   ?itemText   "Slider Example"
                   ?subMenu playMenu)
       (hiAddMenuItem ciwOptionsMenu slider))
  • saurabh96
    Thanks Max,
    It served purpose.
    am glad you understand my question.
    Thomas
