  3. String parameter
  • Views 11654
String parameter
Ali ElBoghdady
Ali ElBoghdady over 4 years ago
Hi all, I have a simple code to show only Metal layers on the keyboard pressing (1,2,3 ..) i.m trying to pass a string as a parameter for a function but i get an error as my string is inside another.
here is the code:
procedure( showMetal(layer)
pteSetActiveLpp(layer)
pteSetNoneVisible(?panel "Layers")
);procedure
hiSetBindKeys( "Layout" list(
list("<key>1" "showMetal("M1 drawing")" "bindKeyCommand1()")
list("<key>2" "showMetal("M2 drawing")" "bindKeyCommand2()")
list("<key>3" "showMetal("M3 drawing")" "bindKeyCommand3()")
list("<key>4" "showMetal("M4 drawing")" "bindKeyCommand4()")
list("<key>5" "showMetal("M5 drawing")" "bindKeyCommand5()")
)) ;; hiSetBindKeys
The error appears at the part:  list("<key>1" "showMetal("M1 drawing")" "bindKeyCommand1()") as M1 drawing is string, so how should i approach this? is it concatenation or something else?
Thanks in advance.
    A quotation mark within a string needs to be escaped with a backslash. So they should be: "showMetal(\"M1 drawing\")" Andrew
  • Ali ElBoghdady
    Ali ElBoghdady over 4 years ago in reply to Andrew Beckett
    Thanks Andrew that worked like a charm !
