  3. Not getting correct path while using browse button to select...
  • Replies 15
  • Views 19686
Not getting correct path while using browse button to select directory
saurabh96
saurabh96 over 4 years ago
I have made a script to browse directory...but when am selecting the directory ,its creating wrong path to directory
path_label=hiCreateLabel(
?name 'path_label ?labelText "Path*"
?justification 'left)
path_enter=hiCreateStringField(
?name 'path_enter
?defValue "/pkg/abc/xyz"
browse_Entry=hiCreateButton(
?name 'browse_Entry
?buttonText "Browse..."
?callback "ddsFileBrowseCB(hiGetCurrentForm() 'path_enter \"*\" 'directoryOnly)"
When am selecting directory /pkg/abc/efg its giving /pkg/.nh/05/efg...that path to directory is wrong and doesn't exist.
IS THERE A WAY WHEN I SELECT ANY DIRECOTRY THROUGH BROWSE OPTION i.e /pkg/abc/klj/ then in text box it automatically comes as realpath of /pkg/abc/klj of this directory?
to avoid above path error
regards,
thomas
    If I've understood you correctly, the issue is that the symbolic links are being expanded when you pick "Choose" on the form (that's what happens for me). I can't see any way it would end up with a path that doesn't exist (unless you have a symbolic link to a path that doesn't exist). Anyway, there was a request a few years ago to not simplify the filename, and there were a bunch of fixes but it appears there's a remaining small issue in the final callback where the path still gets simplified. I've filed CCR 2593053 for that. There's no workaround at the moment. The path should not be incorrect - it's just been resolved - so I don't understand what you're saying above. Please take this up with customer support as somebody will need to see your environment to understand this.
  • saurabh96
    saurabh96 over 4 years ago in reply to Andrew Beckett
    Hello Andrew,
    Is there a way to browse a directory path that contains soft-link in it.
    Suppose there is a directory- thomas and his full path to directory is /pkg/xyz/thomas
    And if i do realpath /pkg/xyz/thomas then it is /pkg/.link/elpase/xyz/thomas ..so is there way to directly put realpath of directory of the directory selected in the textbox.
    thomas
    Andrew Beckett over 4 years ago in reply to saurabh96
    I don't understand. You've now asked for the complete opposite of what you asked for in the first place. Right now if you enter /pkg/xyz/thomas, it expands the links to /pkg/.link/elpase/xyz/thomas and shows that (the "realpath"). Earlier you said you didn't want that, but in the latest append you seem to be saying you do want that. So which is it?
  • saurabh96
    Hello Andrew,
    Sorry for confusion
    let me start again...
    so i have a path to directory say /pkg/xyz/abc/thomas
    Now when i do realpath /pkg/xyz/abc/thomas in my shell window it expands to /pkg/.link/elpase/xyz/abc/thomas
    Now issue is when i browse directory and go one step down /pkg/xyz/abc/ and select any other directory andrew---> /pkg/xyz/abc/andrew
    now isue is that when i do realpath /pkg/xyz/abc/andrew in my shell window it expands to /pkg/.link/sunset/xyz/abc/thomas while in gui text box its showing /pkg/.link/elpase/xyz/abc/andrew which is wrong path.
    So, what the issue and how can i correct it.
    Hope it clears some clouds.
    Thomas
    Thomas,
    It's really not clear. Please contact customer support. As I said, the CCR I've filed is to request that the symbolic links are not expanded when the final return by ddsFileBrowseCB is performed. Maybe that will solve your problem, but I don't think there are any controls over this right now - any change in behaviour will need an enhancement request, so fully understanding precisely what is going on and feeding that into R&D requires you to log a case with support.
  • saurabh96
    Ok, Andrew
    Thanks for guiding..will look into that
    Now,suppose when i browse directory it will give full path to directory thomas in below text box
    How can i delete directories i.e xyz/abc  that when user selects thomas directory from browse button only /pkg/thomas comes...anything between them(directories) automatically gets deleted
    Thomas
    This is a bit odd, but I guess you could just have a callback on the string field take care of this?
  • saurabh96
    Andrew, path value is not fixed its depend on the different directory selected from browse button.
    Here is the script i have used-
    ?name 'path_label ?labelText "Path"
    ?name 'path_enter
    ?name 'browse_Entry
    ?callback "ddsFileBrowseCB(hiGetCurrentForm() 'path_enter \"\" 'directoryOnly)"
    Now when i browse and select directory "test" from browse button i will get /pkg/check/halo/test in string field.
    I want that in string field only /pkg/test appears , or the absolute path should get trimmed..for any directory is been selected.
    My query is how can i do that trim part?
    Thomas
    I still think this is a peculiar model, but the solution is exactly as I described earlier - use a callback on the path_enter field:
    procedure(MyTrimPathCB(form)
      ; this is to stop it keep trimming in a loop - it uses a semaphore
      ; to determine whether we're already inside the callback
      unless(boundp('MyInCallback) && MyInCallback
        let((pat (MyInCallback t))
          pat=pcreCompile("/[^/]*/[^/]*$")
          form->path_enter->value=pcreReplace(pat form->path_enter->value "" 1)
    ?name 'path_enter
    ?callback "MyTrimPathCB(hiGetCurrentForm())"
    ?name 'browse_Entry
    hiCreateLayoutForm(
      'myform
      "Forum test"
      hiCreateFormLayout(
        'lay
        ?items list(path_label path_enter browse_Entry)
    hiDisplayForm(myform)
    By the way, the CCR I filed earlier (to not expand symbolic links) has been fixed quickly by R&D, and will be in the IC6.1.8/ICADVM20.1 ISR24 version due out towards the end of March.
  • saurabh96
    Hello Andrew,
    i tested the above script.
    actually its deleting the last two directory of the path.
    for eg- if path selected is /pkg/power/test/check/thomas then output coming  is /pkg/power/test/
    i want that it should delete the directories in between them...expected output should be -->  /pkg/check/thomas
    Thomas
