  3. Does it have a certain sequence when traversing instances...
  • Subscribers 152
  • Views 2255
Does it have a certain sequence when traversing instances in a cellview using "foreach"?
richardyuan
richardyuan over 4 years ago
I need to write the cell name of each instance of a rather large array(~400x400) to a text file by its location. For example, an array of 2x3 intances with the name "AA"~"FF", the content of the output file should be like this:
AA BB CC
DD EE FF
Each name is placed by the location of each instance. I have  the rough idea of traversing instances in the cellview directly, but I'm not sure about the sequence. Dose it traverse certainly from the left to the right first and then from the top to the bottom? If it is, then the script is simple(suppose the array size is row*col, the origin of top left instance is (x0 y0), the pitch of horizontal and vertical is x_pitch and y_pitch):
foreach(inst cv~>instances
    if(car(instace~>xy) == x0 then printf("\n"))
    printf("%s " inst~>name)
But if the traversing sequence is random. It will be time consuming for the script:
for(i 1 row
    for(j 1 col
            if(col == 1 then printf("\n"))
            if( ((car(inst~>xy) - x0)/x_pitch + 1) == row && ((y0 - cadr(inst~>xy)/y_pitch + 1) == col then
                printf("%s" inst~>name)
In this case, it seems that we need a method to get the instance by the coordinate of its origin. But I didn't find such a method. Any better idea?
    No, the database is not ordered by coordinate. There is some ordering based on the order of creation of the objects, but this is not something that should be relied upon as there's no guarantee that any database operation will preserve the order. It's certainly not documented that there's any reliable order that you can safely rely on, so even if you empirically discover some order you should not use it.
    There's a sort-of discussion about something similar in this post, but I think you can just use:
    procedure(CCFcompareXY(instA instB)
      let(((xyA instA~>xy) (xyB instB~>xy))
        yCoord(xyA) < yCoord(xyB) ||
        yCoord(xyA) == yCoord(xyB) && xCoord(xyA) < xCoord(xyB)
    instances=sort(cv~>instances 'CCFcompareXY)
    This gives the instances bottom to top, and then left to right in each row. If you wanted it top to bottom, then you'd change the less than in:
    to:
    yCoord(xyA) > yCoord(xyB)
    Hope that helps. Then you can just do a foreach(inst instances ...)
  • richardyuan
    richardyuan over 4 years ago in reply to Andrew Beckett
    Thank you, Andrew. It works fine for the mentioned array. (Though I stiil have a little concern about the efficiency of "sort", for the number of instances would be over 30000)
    But I found actually the instances are not placed as an array. I need to check the empty area if any instance exists. I've opened a new thread for that.
    Andrew Beckett over 4 years ago in reply to richardyuan
    I'm not sure why you would be concerned about the sort. I checked with an example where instances were randomly placed, using the sorting method it took 0.5s with 30,000 instances, and 1.8s with 100,000 instances. The sort is a quicksort and is quite efficient. Given that you are asking to order the instances by x and y, there's not much other choice! Well, there might be given the answer I'm about to give with your other post, but I'm sure that would be a slower method in general.
