  3. Is there a method that I can judge if any instance is located...
  • Subscribers 152
  • Views 12398
Is there a method that I can judge if any instance is located at a point?
richardyuan
richardyuan over 4 years ago
For some reason, plenty of instances are placed regularly but not in an array in the cellview. I need to check if any intance exists at some given points. Is that possible?
  • marcelpreda
    marcelpreda over 4 years ago
    If you want to check if a x,y coordinate is already "covered" by some instance , the procedure bellow is what you want
    Check if x:y coordinate is inside bBox
    @return - boolean
    - t if x:y inside
    - nil if outside
    border cases (on edges) are considered inside
    procedure( MyPkgIsXyInsideBBox(x y bBox)
    x >= xCoord(car(bBox)) && x<= xCoord(cadr(bBox)) &&
    y >= yCoord(car(bBox)) && y<= yCoord(cadr(bBox))
    And here is how to call it
    instId->bBox
    ((10.4125 0.85)
    (11.7625 1.275)
    x = 0
    0
    y = 0
    0
    MyPkgIsXyInsideBBox(x y instId->bBox)
    nil
    x = 11
    11
    y = 1
    1
    t
  • richardyuan
    richardyuan over 4 years ago in reply to marcelpreda
    Thank you. But I'm afraid tha's not what I want.
    Over 200x200 instances are supposed to be arranged in fhe form of array, but actually not. I need to check each lowerleft corner of the array if any instance is located on, which means >40000 instances will be examined by the procedure "MyPkgIsXyInsideBBox" for each corner point, and there're >40000 points. This is too much time-consuming.
    Andrew Beckett over 4 years ago in reply to richardyuan
    It's dbInstQuery() that you'd want to use. This uses the OA region query to find objects in a particular area - in this case, instances. If you specify the start/stop levels as 0, it will find top-level instances, and you can specify the area as a zero-area box if you want to find instances under a specific point, specify the bounding box as list(pt pt).
