  3. Performance Considerations on Context Loading, Overhead...
  • Views 10884
Performance Considerations on Context Loading, Overhead of small context files.
ChristophK
ChristophK over 4 years ago
I've around 50 skill context files. Each represents some logical unit and is fairly small (50-500kB). However, user typically has to load all of them before start working. According to "Delivering Products" section context files shall be small, e.g. less than 5 MB. Still I wonder if there any implication on execution speed or moreover on startup time if I would create one large context file out of it. The rationale would be to reduce the overhead of resolving dependencies to other contexts.
Thanks for your advice.
    That note about context size is outdated (I'll send some feedback that it should be removed) since probably at least IC6.1.4 - some of the Cadence contexts are definitely larger. I don't think you should be concerned about the performance and if anything it would be better than separately loading 50 small context files.
