  3. How to call values depending upon the checkbox selected
  • Views 11975
saurabh96
saurabh96 over 4 years ago
Hello ,
I have created a toggle field.
toggle_Entry=hiCreateToggleField(
?name 'toggle_Entry
?choices list(list('aa "test1") list('bb "test2") list('cc "test3"))
?value list(nil nil nil)
path_enter=hiCreateStringField(
?name 'path_enter
?invisible t
Now i want that when  test1 box is tick only then value assign in "path enter"  should be "use1"
when user selects test1 and test3 then value assign in "path enter" should be "use1,3"
and when user check boxes test1,2,3 then value assign should be "use1,2,3"
and same when user doesn't selects any check boxes values assigned should be null
How can i acheive that above?
regards,
Max
    Your name seems to have changed again (it was Thomas yesterday). Anyway, this seems somewhat similar to a previous post of yours. I essentially use the same approach I explained in my reply here.
      ?name 'toggle_Entry
      ?callback list("CCFupdatePathEnter(hiGetCurrentForm())")
    procedure(CCFupdatePathEnter(form)
      let((listOfStrings)
        listOfStrings=
          setof(elem
            foreach(mapcar (toggle data) form->toggle_Entry->value
              list("1" "2" "3") toggle && data)
            elem
        if(listOfStrings then
          form->path_enter->value=strcat("use " buildString(listOfStrings ","))
        else
          form->path_enter->value=""
      ?name 'path_enter
    ; commented out so can see what is going on
    ;  ?invisible t
    hiCreateLayoutForm(
      'ForumForm
      "Forum test"
      hiCreateFormLayout(
        'lay
        ?items list(toggle_Entry path_enter)
    hiDisplayForm(ForumForm)
    Georgina
  • saurabh96
    saurabh96 over 4 years ago in reply to Andrew Beckett
    Thanks Georgina,
    Max is my byname.
    Thanks for guidance!!
