  3. Radio button changes automatically
  • Views 12064
seongminlee
seongminlee over 4 years ago
1. I want to make a radio button that changes automatically.
When you check test1, test2, test3 of MENU1, test1 test2 tset3 of MENU2 should follow automatically
2. ?choices Choices1
When using Choices1 as a list, an error occurs.
Can you guess the cause?
------attached code----
let( (radiofield1 radiofield2)
radiofield1 = hiCreateRadioField(
?name 'radio1
?prompt "MENU1"
?value "test1"
?choices '("test1" "test2" "test3" "test4" "test5")
radiofield2 = hiCreateRadioField(
?name 'radio2
?prompt "MENU2"
?value "test1"
?choices '("test1" "test2" "test3")
;Choices1 = '("test1" "test2" "test3" "test4" "test5")
;Choices2 = '("test1" "test2" "test3")
hiDisplayForm(
hiCreateAppForm( ?name 'myform ?formTitle "Radio Button Test"
?fields (list radiofield1 radiofield2))
    Not really, because you didn't show the code that had the error. Maybe you had ?choices 'Choices1 (i.e. were quoting the variable), which would be wrong, or maybe it was because you set the variable after you used it?
    Anyway, here's the code working using the variables for the choices, plus a callback which does what you asked for in point 1.
    procedure(CCFsetMenu2FromMenu1(form)
      when(member(form->radio1->value form->radio2->choices)
        form->radio2->value=form->radio1->value
        ?name 'radio1
        ?prompt "MENU1"
        ?value "test1"
        ?choices Choices1
        ?callback list("CCFsetMenu2FromMenu1(hiGetCurrentForm())")
        ?name 'radio2
        ?prompt "MENU2"
        ?value "test1"
        ?choices Choices2
      hiDisplayForm(
  • seongminlee
    seongminlee over 4 years ago in reply to Andrew Beckett
    Thank you very much.
    one more question.
    let( (radiofield1 radiofield2 radiofield3 radiofield4 )
    ?name 'radio1
    ?prompt "MENU1"
    ?value "test1"
    ?choices Choices1
    ?name 'radio2
    ?prompt "MENU2"
    ?value "test1"
    ?choices Choices1
    radiofield3 = hiCreateRadioField(
    ?name 'radio3
    ?prompt "MENU3"
    ?value "test1"
    ?choices Choices1
    radiofield4 = hiCreateRadioField(
    ?name 'radio4
    ?prompt "MENU4"
    ?value "test1"
    ?choices Choices2
    hiDisplayForm(
    ?fields (list radiofield1 radiofield2 radiofield3 radiofield4))
    With the above code, Menu1 Menu2 Menu3 should always select the same radio value.
    Menu4 has values of Menu1,2,3
    test1-> test3
    test2-> test3
    test3-> test2
    test4-> test1
    test5-> test1
    How do I make a selection like this?
    Andrew Beckett over 4 years ago in reply to seongminlee
    Rather odd requirement, but this is just a matter of having the appropriate callback logic. The code below means that whenever you set a value of the MENU1/MENU2/MENU3 radio buttons, it replicates the setting to the other two within the set, and then does a mapping to set MENU4. It's really not that complicated to do this - you just need to think about the logic you're trying to implement.
    procedure(CCFsetMenusFromMenuField(form field)
      let((fieldValue)
        fieldValue=get(form field)->value
        ; set the other fields to the value of the field just
        ; changed
        foreach(fieldName '(radio1 radio2 radio3)
          unless(fieldName==field
            when(member(fieldValue get(form fieldName)->choices)
              get(form fieldName)->value=fieldValue
        ; set the final radio button with a mapping from the
        ; chosen value using a case statement
        form->radio4->value=
          case(fieldValue
            (("test1" "test2") "test3")
            (("test3")         "test2")
            (("test4" "test5") "test1")
        t
        ?name 'radio1
        ?prompt "MENU1"
        ?value "test1"
        ?choices Choices1
        ?callback list("CCFsetMenusFromMenuField(hiGetCurrentForm() 'radio1)")
        ?name 'radio2
        ?prompt "MENU2"
        ?value "test1"
        ?choices Choices1
        ?callback list("CCFsetMenusFromMenuField(hiGetCurrentForm() 'radio2)")
        ?name 'radio3
        ?prompt "MENU3"
        ?value "test1"
        ?choices Choices1
        ?callback list("CCFsetMenusFromMenuField(hiGetCurrentForm() 'radio3)")
        ?name 'radio4
        ?prompt "MENU4"
        ;?value "test1"
        ; changed default to match mapping logic
        ?value "test3"
        ?choices Choices2
      hiDisplayForm(
