  3. Is there any way to get only metals exempting the base ...
  • Subscribers 152
  • Views 12576
Is there any way to get only metals exempting the base layers
LakshmanQual
LakshmanQual over 4 years ago
Hi All,
I am working with some metal shapes in the layout. When i try to get the details to the list, I am getting all layers including base layers.
Is there anyway to get only the metal shapes irrespective of path, rect or polygon. Even if they are in group, I need those metal details.
Thanks for the help.
  • Kevin Buck
    Kevin Buck over 4 years ago +1
    It's very unclear what you're asking. You can always iterate over the shapes and then use an if or case statement to execute based on the lpp property. For example: layView = dbOpenCellViewByType(libName…
    Andrew Beckett over 4 years ago in reply to Kevin Buck +1
    tf=techGetTechFile(cv) metalLayerNames=mapcar('car setof(function techGetLayerFunctions(tf) cadr(function)=="metal")) will do it. Andrew
  • Kevin Buck
    layView = dbOpenCellViewByType(libName cellName "layout" "" "r")
    foreach(shape layView~>shapes
        if(shape~>lpp == list("MET1" "drawing") then
            ;do something here
  • LakshmanQual
    LakshmanQual over 4 years ago in reply to Kevin Buck
    Hi Kevin, Thanks for answering.
    I got list of shapes with cvid~>shapes earlier.
    But with this i am getting all the shapes of that layout. I want to segregate only metals from that. As different process or tech nodes will have different naming conventions, I cant use "MET1" or "MET2" directly. Is there any unique property i can separate only metals out of all those shapes?
  • Kevin Buck
    Kevin Buck over 4 years ago in reply to LakshmanQual
    Not that I'm aware of but you can probably create a lookup file that sources your technology file to find them. I've worked with several PDKs and there are usually not too many variations on the layer names.
    will do it.
  • LakshmanQual
    LakshmanQual over 4 years ago in reply to Andrew Beckett
    Thanks Andrew, Its working. It was a great help!!
