  3. Escaping backslash in pcreReplace patterns
  • Views 12647
Driss
Driss over 4 years ago
Hello Skill Community
I am getting into trouble when trying to escape backslash characters with PCRE expressions in skill.
My goal is to replace underscore characters in a given input string with   "\_" or sometimes with  "\\\_"
So for instance:
inputSTR="TYP,Plan.3.Insertion_Loss_Fund_ATT0_TYP"
comPat1 = pcreCompile( "_" 0)
pcreobj@0x2e0be120
pcreReplace(comPat1 inputSTR "\\_" 0)
I put 2 blackslash characters in the last statement to escape its special meaning in Skill and would expect then this return:
"TYP,Plan.3.Insertion\_Loss\_Fund\_ATT0\_TYP"
Similarly, if I would like to get 3 backslash in the end result, I would try this statement:
pcreReplace(comPat1 inputSTR "\\\\\\_" 0)
But skill returns:
"TYP,Plan.3.Insertion\\_Loss\\_Fund\\_ATT0\\_TYP"
as I would expect:
"TYP,Plan.3.Insertion\\\_Loss\\\_Fund\\\_ATT0\\\_TYP"
Can someone explain me where is my failure?
Thank you all in advance
Cedric
  • mbracht
    mbracht over 4 years ago
    Hi Cedric,
    For each literal backslash in the result you need to specify 4(!) backslashes in your pcreReplace() call.
    So that creates one backslash:
    (pcreReplace (pcreCompile "_")  "A_B" "\\\\_" 0)
    ...and that one two:
    (pcreReplace (pcreCompile "_")  "A_B" "\\\\\\\\_" 0)
    Dont't let yourself get confused by the output in the CIW, literal backslashes as a return value are always indicated with another leading backslash:
    "A\\_B"
    Just write the resulting string in a file and you will see that everything is as expected.
    Max
  • Driss
    Driss over 4 years ago in reply to mbracht
    Indeed, thanks for your answer!
