  3. Cant Clear Mark net
  • Subscribers 152
  • Views 12237
Cant Clear Mark net
John Z
John Z over 4 years ago
I have accidently Mark Net some of the metal that have short connection. I used ctrl+c to terminate the process. Then somehow when i tried to UnMarkNet those net nothing happen. It couldn't be remove unless i restart my cadence.
I used cadence IC 6.1.7. Let me know if you guys have any solution on this whether by using Skill to refresh the database or any method might help.
Adam
  • psill00
    psill00 over 4 years ago
    If you do a close data of the cellview/s it should go away
  • John Z
    John Z over 4 years ago in reply to psill00
    I have restart the cell view several times. But, its still there. Btw thanks for your response.
    Andrew Beckett over 4 years ago in reply to John Z
    I found a report of a similar issue, CCR 2062930 which was fixed in IC6.1.8 ISR4. As a workaround, you can (I think) do this:
    geDeleteAllHilightSet(geGetWindowCellView())
    in the CIW.
