  3. does skill support if else if loop ?
  • Subscribers 152
  • Views 18883
GDCRA
GDCRA over 4 years ago
Hi
My skill procedure is reading file line by line and based on line content, I need to execute different actions on schematic design. In short,  I have more than one test condition but only the statements of one test need to be executed.
I have all necessary command to execute my task, it just I am not able to use if else if or cond statement.
My questions are , Does skill support if else if statements ? If yes, can someone body syntax skeleton or point to example ?
If, if else if is not supported, what other construct i can use ?
GD
  • drdanmc
    drdanmc over 4 years ago in reply to mbracht +1
    Here is an example of cond(). I use cond if I want somewhat arbitrary tests. For example x = -3.2 msg = "save" cond( ( x > 1.0 printf("x > 1.0 is true\n") ) (msg == "open" printf("msg…
  • mbracht
    mbracht over 4 years ago
    SKILL does not explicitly support an elseif branch but it can easily be achieved in terms of a nested if statement:
    (if <condition> then
        <do something...>
    else
       (if <someOtherCondition>
          <do something else...>
    Personally I would prefer   a case statement though...
    (case
       (<condition1>
          ...do something
       (<condition2>
          ...do something else
       (<conditionN>
          ...do whatever
    regards
    Max
    • Vote Up -1 Vote Down
  • drdanmc
    x = -3.2
    msg = "save"
    cond(
        ( x > 1.0
        (msg == "open"
            printf("msg is \"open\"\n)
        ( stringp(msg)
           printf("msg is a string that is not handled:  %L\n" msg)
       (t
          printf("default action\n")
    in the above, the first matching condition and only the first matching condition is executed.
    for the situation where each condition is checking the same variable but against different values, I use case or caseq as Max suggests.
    -Dan
