  3. retrieve the net name connected to pcell symbol
  • Views 12913
mctang21
mctang21 over 4 years ago
Hi
I have pcell symbol. I would like to invoke callback "update_net_prop" when a CDF parameter of this pcell instance is updated. The callback would change the property of the net connected  to the terminal of this pcell instance. How do I retrieve the net name connected to the terminal of this pcell instance ?
cdfCreateParam( cdfId
?name "padNum"
?prompt "Number of ports"
?defValue 1
?type "int"
?display "artParameterInToolDisplay('padNum)"
 ?callback "update_net_prop()"
ManChak
  • mctang21
    Hi
    I figured out how to retrieve the net myself already. Please ignore my question above. How do I specify  "Form Done Procedure" using SKILL code ?
    I added "PrintSchNet"  to the form manually.
    ManChak
  • Kevin Buck
    Kevin Buck over 4 years ago in reply to mctang21
    Define it in your .cdsinit file.
  • mctang21
    mctang21 over 4 years ago in reply to Kevin Buck
    Hi Kevin,
    Thank you for your info. Could you tell me the syntax which associates my pell_symbol,il and CDF.il with post done procedure in .cdsinit ?
    ManChak
  • Kevin Buck
    I don't understand your question. You need to define the function in your .cdsinit file:
    procedure( printSchNet()
              ;Put your code here
  • mctang21
    HI Kevin,
    Thank you. My original question is how to specify printScNet in the CDF form without editing CDF form manually after coding " procedure( printSchNet()" ?
    Is it doable ?
    ManChak
  • Kevin Buck
    Yes. Brief example code:
    LIBRARY = "test_8nm_lib"
    CELL = "myparsubckt"
    let( ( libId cellId cdfId )
    unless( cellId = ddGetObj( LIBRARY CELL )
    error( "Could not get cell %s." CELL )
    when( cdfId = cdfGetBaseCellCDF( cellId )
    cdfDeleteCDF( cdfId )
    cdfId = cdfCreateBaseCellCDF( cellId )
    cdfId->doneProc = "printSchNet()"
