  3. Automatically loading some libraries into my cds.lib
  • Views 14832
mak22
mak22 over 4 years ago
I am sure there is a file where we can do this.
When I open my virtuoso, we can obviously see the project libaries, but I want to always open a few more libraries automatically that will help my productivity.
Rather than editing my cds.lib each time, is there a file where I can append to the central libraries?
flow of library loading:
1) load all project central libraries
2) load all user specified libraries
3) create final cds.lib that combines #1 and #2.
Thank you
  • AurelBuche
    AurelBuche over 4 years ago
    You should have a look at the following support articles:
    1. Using SKILL, how to get paths of other cds.lib files used in your cds.lib by INCLUDE/SOFTINCLUDE statement? Difference between INCLUDE/SOFTINCLUDE.
    2. How to access the libraries defined in a different cds.lib file and how to get the path of the current cds.lib file in use?
    Based on this I believe you could achieve this in your .cdsinit or whatever SKILL file is loaded at Virtuoso startup in your setup
    You should create two cds.lib, a project one and a user one and include them in a custom one which Virtuoso will load
    Here is an example snippet of what you could do (note that I haven't tested it):
    (letseq ((path (simplifyFilename "./custom.cds.lib"))
             (port (outfile path))
      (fprintf port "INCLUDE %s\nINCLUDE %S\n" <path_to_project_cds.lib> <path_to_user_cds.lib>)
      (close port)
      (ddSetForcedLib path)
      (ddUpdateLibList)
    Cheers,
    Aurélien
