  3. Field to display all nets in layout and filter as I typ...
  • Views 10742
Field to display all nets in layout and filter as I type
prasadtammana
prasadtammana over 3 years ago
I want to create a field with dropdown menu that displays all net names in my layout and it should filter the net names as I type. leCreateNetField is working as I expected but its not allowing me to add any new net name that's not present in the list.
So, I started using hiCreateComboField, which allows adding a new net name also. But I'm missing the filter option. Either I should completely type the net name or select one of the all net names displayed from drop down. Is there a way to add filter feature to hiCreateComboField?
Prasad
  • mbracht
    mbracht over 3 years ago
    Hi Prasad,
    The hiCreateComboField function lets you define a modifyCallback that is triggered whenever a change is made in the field. I haven't tried this out myself yet but reconfiguring the choices of the combo field in that callback should work.
    regards
    Max
  • mbracht
    I just found a piece of example code that does the job...
    let((cf (cv (geGetWindowCellView)) )
        cf=hiCreateComboField(
            ?name 'cf
            ?items cv~>nets~>name
            ?modifyCallback
                lambda((field form value flag)
                    let((len)
                        len=strlen(value)
                        form->cf->items=setof(item form->cf->allItems
                            strncmp(item value len)==0) t)))
        cf->allItems=cf->items
        hiCreateAppForm(
            ?name 'CCFform
            ?fields list(cf))
        hiDisplayForm(CCFform))
    Max
  • prasadtammana
    prasadtammana over 3 years ago in reply to mbracht
    Hi Max, Thanks for the quick reply. Adding modifyCallback function as you suggested is filtering the net names. But I want to have more interactive drop down menu just like in leCreateNetField, where the drop down menu highlites the net names that matches with the net name that we are typing.
    Do you know if there is a way to add an option to leCreateNetField to allow it to take new inputs as well?
    Prasad
  • AurelBuche
    AurelBuche over 3 years ago in reply to prasadtammana
    Hi Prasad,
    The leCreateNetField is completely custom made by Cadence so you won't have the possibility to tweak it
    Here is a quick overview of what is inside the different fields:
    ;; Combo Field
    > (hiCreateComboField ?name 'combo_field ?items (geGetEditCellView)~>nets~>name)
    comboStruct@0x3dfed6e0
    > comboStruct@0x3dfed6e0->?
    (_focusInCallback usedIn invisible items highlightType
        nextField enabled editable echoOn prompt
        _formatSpec _modifyCallback _callback fieldType hiFieldSym
        modified defValue lastValue _activeUT value
    ;; Net Field
    > (leCreateNetField 'nets_field ?window (hiGetCurrentWindow))
    nativeStruct@0x3dfed6f8
    > nativeStruct@0x3dfed6f8->?
    (usedIn invisible enabled _userData _factory
        prompt fieldType hiFieldSym _activeUT
    > nativeStruct@0x3dfed6f8->_userData
    (leNetComboBoxNative name "leNetComboBoxNative" value ""
        window window:3 callback "" maxVisibleItems
        10 enabled nil invisible nil
        maxWidth 0
    ;; Layer Field
    > (leCreateLayerField 'layer_field ?techFile (techGetTechFile (geGetEditCellView)))
    nativeStruct@0x3e24d9e0
    > nativeStruct@0x3e24d9e0->?
    > nativeStruct@0x3e24d9e0->_userData
    (leLPPComboBoxNative name "leLPPComboBoxNative" value ""
        callback "" appendChoices nil prependChoices
        nil maxVisibleItems 10 syncedPaletteWindow nil
        techFile db:0x2454c01a layerFunction "" enabled
        nil invisible nil maxWidth 0
    As you can see, there is not much _userData available in the leCreateNetField to customize it
    You could request an enhancement of the combo fields to make them more interactive. This would be a nice feature as they are often used
    Hope this helps you a little
    Cheers,
    Aurélien
