  3. techSetTechLibName equivalent to Attached a tech lib ?
  • Subscribers 150
  • Views 13075
ebecheto
ebecheto over 4 years ago
Does anyone know if the function techSetTechLibName is the equivalent of the Menu-> Tools->Technology File Manager -> Attached ...  ?
Does anyone know how to report a little error in the documentation, because in the documentation using virtuoso IC6.1.8
Documentation :
techSetTechLibName(
g_ID
t_libName
=> t / nil
Example
techSetTechLibName(libID ddGetObj("libName"))
=> t
I think it should me corrected to :
Example
techSetTechLibName(libID  "lib_prim")
techSetTechLibName(ddGetObj("libNameSource") "libName")
=> t
;<= where libNameSource is the name of the target library, and libName is the name of the Technology library to attached,
    Strictly speaking, techBindTechFile is the equivalent of attach (in fact techSetTechLibName tells you to use this).
    Normally to give feedback on a page, you'd click on the "Send Feedback" flag in the bottom right if using cdnshelp. The same is there on Cadence Online Support. For the specific correction here, I just gave the same feedback so no need to do it yourself this time.
